Axle clip - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 21st, 2014, 07:14 PM   #1
hoyt5885
hoyt5885's Avatar
Default Axle clip
I have a dana 35 with a Detroit tru trac and the driver side axle clip Is stuck will not come off wondering if there is a way to get it unstuck
hoyt5885 is offline   Reply With Quote
Old January 21st, 2014, 07:22 PM   #2
in2deep
Hole tester
stuck as in you can push the shaft in to get the clip out or cant get the clip of shaft.
Old January 21st, 2014, 07:25 PM   #3
hoyt5885
hoyt5885's Avatar
Can't get clip off shaft
Old January 21st, 2014, 07:28 PM   #4
Dylan
Dylan's Avatar
may be twisted splines so the axle is not being pushed in far enough to get the c clip to release. try tapping in on the shaft with a bigger hammer.
Old January 21st, 2014, 07:43 PM   #5
hoyt5885
hoyt5885's Avatar
Shaft is in as far as it will go I have a clamp holding it in
Old January 21st, 2014, 07:47 PM   #6
in2deep
Hole tester
beat it off with a punch and hammer, last resort cut it off
Old January 21st, 2014, 10:13 PM   #7
unclebeaner
can you hear the banjos?
unclebeaner's Avatar
x2
Old January 21st, 2014, 10:18 PM   #8
MARTIN HASSENGER
BRONCATRON
MARTIN HASSENGER's Avatar
I've had where there was enough oil left to make it stick onto the side gears and axle shaft, compressed air and someone taping on the shaft with a hammer seemed to work. Best of luck
MARTIN HASSENGER is offline   Reply With Quote
Page generated in 0.22493 seconds with 47 queries
