Toy axle knuckle stud upgrade - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 21st, 2014, 08:28 AM   #1
yota85
yota
yota85's Avatar
Default Toy axle knuckle stud upgrade
I am building a new axle for my yota, was wondering what some of the guys on here that are running toy axles are running for knuckle/steering upgrades, and some reviews on how it has held up pros/cons? 5th stud, 6 shooters, arp studs, 9/16 studs, trunion eliminator, marlins 25mm pins??
yota85 is offline   Reply With Quote
Old January 21st, 2014, 09:06 AM   #2
I always ran ARP studs from FROR, with Marlin 4 bolt steer arms. I never had any issues with anything loosening or shearing.
1st setup: 36x12.5 SXs on stock axle with 1.5" spacers, lunchbox locker
2nd setupt 385x14.5 SXs on +6" diamond axle, lunchbox locker.
I was going to upgrade to hydro assist, just never got around to adding it before I sold the truck. I'd have considered a 5th stud at that point.
Old January 21st, 2014, 09:14 AM   #3
yota85
yota
yota85's Avatar
Thanks for the input, I am leaning towards arp studs, I'm running 1.5 spacers with 37x12.5's I really don't wheel really hard, but I want it reliable and off my mind wile out and about
Old January 21st, 2014, 12:32 PM   #4
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Arp's, trunion eliminator, 5th stud. Stood up to 38.5 tsl sx's and hydro assist with zero issues
Old January 21st, 2014, 02:30 PM   #5
yota85
yota
yota85's Avatar
What was your opinion on the trunion eliminator? Would you run it again?
Old January 21st, 2014, 04:50 PM   #6
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
For sure....it was a pain in the ass getting it shimmed right when installing it....not in a difficult way, but in a tedious way....other than that it was awesome. Some people complain it is not smooth and has "sticky" spots when turning but i never noticed it....likely because i had hydro assist which, if you don't have, you need to get running 37's.
Old January 21st, 2014, 08:39 PM   #7
yota85
yota
yota85's Avatar
Hydro assist is Definetly on the list, thanks for the input, I ordered my arp's today, looking into marlins 25mm upgrade, there arms have been out of stock for wile now, trying to hunt some arms down, don't really want to machine my trail gear arms.
Old September 4th, 2014, 12:12 AM   #8
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
I know this is a old post but this just happened with ARP's, Trail Gear arms and stock knuckles. I just pulled the trigger on a set of Six Shooters.
Sheered off the studs and cracked the knuckle in 2 places.
Old October 14th, 2014, 05:08 PM   #9
yota85
yota
yota85's Avatar
Yea that's the route I ended up going, 6 shooters, arp studs with trunion bearing eliminator. No problems so far,
Old October 16th, 2014, 01:53 PM   #10
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
The problem with the arp studs is people don't get or keep them tight enough. It's not a shearing issue, it's a clamping issue. The shearing is a product of them coming loose. Lots of good info here
http://www.google.com/url?sa=t&sourc...77648437,d.aWw
The 6 shooters are a waste in my eyes. If you get the arp's and keep them tight then add a grade 8 1/2 bolt....something like this
You will be just fine. I and many others have beat this setup silly on 38"+ tires with almost no failures....i have first hand seen the pins on the steering arm (the plus sized Marlin ones) break and the studs be fine.
Old May 11th, 2015, 03:07 PM   #11
toyotaguy
toyotaguy's Avatar
i ran arp's with locktite torqued with a torque wrench for 2 years wheeling every weekend with hydro-assist and 37's with 1.5' spacers with no problems. ended up having trunion bearing failure and went to 6-shooters with arp's all the way around again with locktite. no issues there either just upgraded for extra insurance. don't buy trail gear tre's though, they didn't last more than a few months
toyotaguy is offline   Reply With Quote
Old May 13th, 2015, 06:12 AM   #12
stereoguy
2jz NO SH*T!
stereoguy's Avatar
I am just running arps with locktite for a few years hydro assist with 39.50's. So far no issues. I do a pre wheeling check before and after to check bolts for tightness and most everytime one is a tiny bit loose. If I didn't do this I am sure I would have had a failure. I am doing the trunion eliminator soon I may go the 6 shooters or the 5th stud mod at that time.
stereoguy is offline   Reply With Quote
Old May 16th, 2015, 12:14 AM   #13
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
I hit the studs with the impact the day they broke. But it was a hard hit.
Old March 1st, 2016, 06:06 PM   #14
generalyota
Ridge Runners Offroad
generalyota's Avatar
I didn't run the ARP studs because they can destroy the toyota knuckle when put under alot of force. I have the Marlin studs and I have not broken one or had one loose yet. I plan on going to 6 shooters if anything breaks on my knuckles. If I break another R&P im going tons and calling it a day. The main thing with steering arm studs it making sure they are torqued properly and rechecked before each wheeling trip.
generalyota is offline   Reply With Quote
Page generated in 0.24565 seconds with 65 queries
