Ram assist question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 20th, 2014, 12:17 PM   #1
Hoss Blazer
!SPARTY ON!
Hoss Blazer's Avatar
Default Ram assist question
What's the difference between the tie rod cylinder and the welded cylinder style ram assist rams? I'm looking for either a 1.5 or 1.75 x 8 ram to finish up my setup. I haven't found many makers for these in the tie rod style, mostly are 2x8 or bigger. But there's many different companies that make the welded style like PSC.....
Old January 20th, 2014, 01:50 PM   #2
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
When you say "tierod" are you talking about heims at both ends? And "welded" meaning fixed non-heim ends? Or do you mean welded heims on both ends instead of adjustable ones?
Old January 20th, 2014, 02:15 PM   #3
BigBlockBlazer
Axle breakin' 101
http://www.pscmotorsports.com/motors...-cylinder.html
This has everything to get it done and not have to scrounge for parts.
http://www.surpluscenter.com/Hydraul...S-9-7258-8.axd
This would work also but the ends are not adjustable.
Old January 20th, 2014, 02:16 PM   #4
koochman450r
koochman450r's Avatar
I think he's talking about the cylinders that are held together with the threaded rods and the other style.
you won this battle.
Old January 20th, 2014, 02:20 PM   #5
BigBlockBlazer
Axle breakin' 101
Ahh, forgot about those, than use the welded / heim cylinder for sure. And knowing Hoss he's looking for the cheapest shit he can find.
Old January 20th, 2014, 02:25 PM   #6
Tie rod cylinders are generally a lesser duty requirement.
Old January 20th, 2014, 02:51 PM   #7
Hoss Blazer
!SPARTY ON!
Yes this is what in talking about. I didn't know if there was a difference from the PSC style or the style that is square @ both ends. Someone told me that the PSC style isn't rebuild able compared to the one that you can take the end off.
Now why ya gotta be like that!! But your so true, PSC is not cheap compared to the ones I looked at the other day @ tractor supply & surplus supply!
Old January 20th, 2014, 03:10 PM   #8
Lousypirate
Whoop Whoop
Lousypirate's Avatar
$.02
if you find one that is normal stock for TSC, you can always pick up a replacement as long as you are close to a TSC
The Kernel (46 CJ2a)
Wow, i would lick those...
Lousypirate is online now   Reply With Quote
Old January 21st, 2014, 12:00 PM   #9
Hoss Blazer
!SPARTY ON!
So this is what it comes down to, since they don't make the tie rod style in that size....
PSC...1.75x8
PSC...1.50x8
Surplus Supply...1.5x8
http://www.surpluscenter.com/Hydraul...E-9-7706-8.axd
Old January 21st, 2014, 12:12 PM   #10
For an assist cylinder, I would stay away from a tie rod style. They are bigger & harder to package.
Old January 21st, 2014, 12:47 PM   #11
BigBlockBlazer
Axle breakin' 101
None of your links work.
Old January 21st, 2014, 12:48 PM   #12
alboy79
Where's your loyalty lie?
alboy79's Avatar
My assist on my 79 bronco was a TSC 2x8. Worked fine.
"Skill that is untested does not equate to actual skill." Test yourself!
Don't tell me what you've done.
Show me what you can do.
alboy79 is offline   Reply With Quote
Old January 21st, 2014, 01:16 PM   #13
Hoss Blazer
!SPARTY ON!
Well shit!!
Guys @ PSC said that a 2x8 is gonn be to big and laggy for just ram assist.
Old January 21st, 2014, 01:29 PM   #14
BigBlockBlazer
Axle breakin' 101
I used a tsc 2x8 to start out with and it was slow as balls one way and slower that shit the other.
Old January 21st, 2014, 02:09 PM   #15
Hoss Blazer
!SPARTY ON!
Links fixed and my friend used the tsc 2x8 on his m37 w/ full hydro and seamed to work well but it was a completely different setup than yours bigblockblazer
Old January 21st, 2014, 02:11 PM   #16
BigBlockBlazer
Axle breakin' 101
I used it in full hydro mode only and it was slow.
Old January 21st, 2014, 04:25 PM   #17
bbaXJ
Yooper In Training
bbaXJ's Avatar
PSC...1.75x8
PSC...1.50x8
I'm no expert, but the last one seems like the best bang for the buck route, assuming you have an inexpensive source for the brackets and hardware.
Old January 22nd, 2014, 08:48 PM   #18
Torg38
TorgFab
Torg38's Avatar
I used the surplus center heim end style 1.5x8 for hydro assist off a Plumbed box. Works great. Never noticed any lag but I'm not auto crossing with it:)
Torg38 is offline   Reply With Quote
Old January 22nd, 2014, 09:29 PM   #19
michigan maniac
michigan maniac's Avatar
I have a psc ram sitting in the closet for my hydro assist on the jeep, now I'm wondering if it will be fast or slow, my full hydro on my bdmt is fast, and for that I used a ram and orbital from a combine... The ram used standard style looking one ton-ish tie rods...
Old January 22nd, 2014, 09:44 PM   #20
michigan maniac
Psc are rebuildable and looks for a round $20 for a seal kit http://www.pscmotorsports.com/motors...ts?cat=465&p=2
Keep in mind a tsc ram, or surplus ram will more then likely be easier to just buy another new one instead of trying to search and track down the correct seals for it
Page generated in 0.31019 seconds with 83 queries
