Sold 77 chevy partout *PRICE DROP NEEDS TO GO* - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 20th, 2014, 10:14 AM   #1
Lousypirate
Whoop Whoop
Lousypirate's Avatar
Default Sold 77 chevy partout *PRICE DROP NEEDS TO GO*
Rest of parts need to go, trying to gather up enough funds for down payment on house and some repairs to it to get it move in ready.
Here is the build, plenty of photos.
http://www.greatlakes4x4.com/showthread.php?t=195919
Most of what's left:
-Propane setup- $450, now $400, two tanks, two sets of brackets, mixer, regulator, line. One tank full. Impco Model E
-np203/205 doubler. ORD doubler bracket, made my own shift linkage (as seen on Kettering University's website) $1000 obo NOW $800
- custom front and rear bumpers, custom side steps (front bumper welded to be air tank. Front bumper is 6-7gal air tank, poly body mount bushings. fenders trimmed, shackle flip in rear. Needs crack on steering box portion of frame welded. Will part out out sell whole. No major rust, just some surface.
Hood, typical stress cracks, minor surface rust $40
-driveshafts (2 front, 1 rear) all slip on shaft, no slip yokes. new (or relatively new) joints on all $75 now $50 each
45-49"
32"-35" (w/ flange)
32"-35" (w/ flange and cv)
3" lift block and angle shims $20 now $10
custom aftermarket Grille $40
I'm sure I'm missing something. Will sell whole, prices are OBO and would like to have a decent amount of it sold to make it worthwhile to part out... everything is obo, might take some trades. Could use a nice bolt action rifle for some longer distance shooting/hunting, try me on anything else.
Willing to ship anything reasonable on buyers dime
Truck is located in kentwood, but I'm in Norton shores.specific pictures upon request.
The Kernel (46 CJ2a)
Wow, i would lick those...
Lousypirate is offline
Old January 20th, 2014, 02:47 PM   #2
dmcjeep
dmcjeep's Avatar
412 sbc heads are they aluminum or just the stock replacement heads? Any idea on a rough HP rateing on the motor?
dmcjeep is offline
Old January 20th, 2014, 03:04 PM   #3
Lousypirate
Whoop Whoop
They are the ones I bought from you
my guess would be between 350-400?
I will pull cam specs when I get home, They are the iron world racing S/R heads (76cc)
I put a cam similar to what compcams reccomended
Stock pistons with oversized rings
porting and polishing on the iron heads
dual plane aluminum intake with provisions for square and spread bore carbs.
Old January 20th, 2014, 03:46 PM   #4
deerebowtie
Unchained
deerebowtie's Avatar
price for a cab with front clip? Interior can be gutted, don't care.
deerebowtie is offline
Old January 20th, 2014, 04:21 PM   #5
Lousypirate
Whoop Whoop
$600 no doors, $700 doors, gutted
Old January 20th, 2014, 05:51 PM   #6
Lousypirate
Whoop Whoop
This is the cam specs. Pardon the stationary.
Old January 21st, 2014, 06:34 AM   #7
fabricator
throttle jockey
fabricator's Avatar
how much for the frame and body?
fabricator is offline
Old January 21st, 2014, 06:40 AM   #8
Lousypirate
Whoop Whoop
- custom front and rear bumpers, custom side steps (front bumper welded to be air tank. Front bumper is 6-7gal air tank, poly body mount bushings. fenders trimmed, shackle flip in rear. Needs crack on steering box portion of frame welded. Price for gutted body with front clip and frame. No doors $900
Meant this as frame & body, probably priced it a little low though. oh well.
Old January 21st, 2014, 06:52 AM   #9
redhead_823
redhead_823's Avatar
Are the pistons stock diameter and the rings .060 over? Or are they "stock style" .060 over pistons and rings?
Also, I'll take the harnesses.
redhead_823 is offline
Old January 21st, 2014, 06:53 AM   #10
Lousypirate
Whoop Whoop
they are stock pistons, with .060 over rings. Same as the the previous motor. I just had it honed and went with it.
I'll save them for ya
Old January 21st, 2014, 06:56 AM   #11
redhead_823
So you have over .060 gap between the piston and bore wall? Mine slapped a lot with a .005 over hone.
Old January 21st, 2014, 06:57 AM   #12
Lousypirate
Whoop Whoop
It never slapped before, and it was just a hone to even out the surfaces, didn't change the bore size by much.
Old January 21st, 2014, 09:34 AM   #13
redhead_823
Are you sure the pistons are stock size? Did you measure them?
If they are really .060 smaller than the bore, the piston will cock, the ring will not seal, and you will get mega blowby like before.
Old January 21st, 2014, 10:04 AM   #14
Lousypirate
Whoop Whoop
There was no wear on the pistons, and the O/R was on the sides of the wall. I put the pistons that came out back in. I don't remember the measuremetns but they seemed to fit quite well when I installed them. I am not worried about it for a truck motor, nor was my machinist for that matter. If you want to turn 7000 RPM, I wouldn't use this motor in it's current state. The motor was built for torque and low end power.
Old January 21st, 2014, 10:13 AM   #15
redhead_823
If they fit well, then they must not be stock pistons.
Old January 21st, 2014, 10:16 AM   #16
Lousypirate
Whoop Whoop
They're old, so no idea if stock/aftermarket... just that they are vintage . but nothing seemed off in installation.
They'll do better than your pushrods
Old January 21st, 2014, 03:36 PM   #17
Lousypirate
Whoop Whoop
Bump
Old January 22nd, 2014, 01:11 PM   #18
Lousypirate
Whoop Whoop
up
Old January 22nd, 2014, 02:45 PM   #19
FORD FLARESIDE
6'-1" 185lb 14YO Griffin
FORD FLARESIDE's Avatar
I think we need to come up with some kind of deal on those Rims and Tires....................willl discuss soon.
FORD FLARESIDE is offline
Old January 22nd, 2014, 03:06 PM   #20
Lousypirate
Whoop Whoop
I'm assuming this might have to deal with a certain kawi
Page generated in 0.43601 seconds with 85 queries
