Dana30 low pinion - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 19th, 2014, 12:31 PM   #1
Mycj7
Default Dana30 low pinion
My question is I have 2:72 gears in my dana 30 and want to put a good used set of 4:10's in it. It is a low pinion with a long pinion gear. I seen on another forum the cj dana 30 low pinion is the same as the TJ Wrangler and the 2000-2001 XJ Cherokee.
Are the ring and pinion and carrier interchangeable? Is the pinion gear short or long?
Mycj7 is offline   Reply With Quote
Old January 19th, 2014, 12:59 PM   #2
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Carriers can swap ring and pinion no. Cj is long pinion tj/xj/late zj are short. Early zj were long but crush sleeve where Cj uses shims
Old January 21st, 2014, 10:42 PM   #3
Andy456123
Guest
if it is a 2.72 ratio and a 'long' pinion, that is a standard rotation CJ-era D30.
The ring and pinion is not interchangeable with a later model Jeep D30, but the carrier and parts inside the open carrier (spider and side gears) are interchangeable. The carrier split on a D30 is 3.54 and down (numerically speaking) and 3.73 and up.
Andy456123 is offline   Reply With Quote
Page generated in 0.16908 seconds with 32 queries
