!!! SOLD !!! Wolf CVA Muzzle Loader !!! Sold !!! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 16th, 2014, 04:04 PM   #1
busyfixin
Balls Deep
busyfixin's Avatar
Default !!! SOLD !!! Wolf CVA Muzzle Loader !!! Sold !!!
CVA WOLF Muzzle loader.
I got this in a trade deal, and don't like inlines. It is in pretty good shape, although not mint. It has a scope, sling, and recoil reducer on it. I can probably roust up a couple odds and ends, powder pellets, and saboted bullets for it, and I think there is a manual and spare parts baggy.
$175 OBO as it is with the few extras I have for it. Or will trade for a Guns, Ammo, Samurai case, etc.
Sold locally to a friend for $140.
ID:	113679   Click image for larger version
ID:	113680   Click image for larger version
ID:	113681   Click image for larger version
busyfixin is offline
Old January 21st, 2014, 04:49 PM   #2
busyfixin
Balls Deep
busyfixin's Avatar
bump! Offers?
Old January 22nd, 2014, 09:05 AM   #3
Shayne_354
Shayne_354's Avatar
I want this but ur so far away!! Can it be mailed?
Shayne_354 is offline
Old January 22nd, 2014, 09:18 AM   #4
SS
Bananarama!
SS's Avatar
Here is the definition from the BATFE page. There are a few exceptions.
What qualifies as an antique firearm?
As defined in 18 U.S.C. 921(a)(16) the term “antique firearm” means —
any firearm (including any firearm with a matchlock, flintlock, percussion cap, or similar type of ignition system) manufactured in or before 1898; or
any replica of any firearm described in subparagraph (A) if such replica —
is not designed or redesigned for using rimfire or conventional centerfire fixed ammunition, or
uses rimfire or conventional centerfire fixed ammunition which is no longer manufactured in the United States and which is not readily available in the ordinary channels of commercial trade; or
any muzzle loading rifle, muzzle loading shotgun, or muzzle loading pistol, which is designed to use black powder, or a black powder substitute, and which cannot use fixed ammunition. For purposes of this subparagraph, the term ‘antique firearm’ shall not include any weapon which incorporates a firearm frame or receiver, any firearm which is converted into a muzzle loading weapon, or any muzzle loading weapon, which can be readily converted to fire fixed ammunition by replacing the barrel, bolt, breechblock, or any combination thereof.
ATF has previously determined that certain muzzle loading models are firearms and subject to the provisions of the Gun Control Act of 1968 (GCA). All of these guns incorporate the frame or receiver of a firearm that is capable of accepting other barrels designed to fire conventional rimfire or centerfire fixed ammunition. Therefore, these muzzle loading models do not meet the definition of “antique firearm” as that term is defined in the above-cited 921(a)(16) and are “firearms” as defined in 18 U.S.C. 921(a)(3)
Furthermore, as firearms, the models described above, as well as other similar models, regardless of installed barrel type, are subject to all provisions of the GCA. Persons who purchase these firearms from licensed dealers are required to fill out ATF Form 4473 and are subject to a National Instant Background Check System (NICS) check. Convicted felons and certain other persons are prohibited from receiving and possessing these firearms.
The following is a list of weapons that load from the muzzle and remain classified as firearms, not antiques, under the purview of the GCA since they incorporate the frame or receiver of a firearm:
Savage Model 10ML (early, 1st version).
Mossberg 500 shotgun with muzzle loading barrel.
Remington 870 shotgun with muzzle loading barrel.
Mauser 98 rifle with muzzle loading barrel.
SKS rifle with muzzle loading barrel
RPB sM10 pistol with muzzle loading barrel.
H&R/New England Firearm Huntsman.
Thompson Center Encore/Contender.
Rossi .50 muzzle loading rifle.
This list is not complete and it frequently changes; therefore, there may be other muzzle loaders also classified as firearms. As noted, any muzzleloader weapon that is built on a firearm frame or receiver falls within the definition of a firearm provided in 921(a)(3).
Per the law it is not a firearm. No issue with popping it into a box and mailing it out.
All of that is a direct quote from the lawyers on MGO. This question was just asked recently.
-Jer
SS is online now
Old January 22nd, 2014, 09:35 AM   #5
ajmorell
Almost any gun can be shipped, it just depends on whether it needs to go through an ffl. A muzzleloader does not require an ffl transfer
ajmorell is offline
Old January 22nd, 2014, 09:55 PM   #6
busyfixin
Balls Deep
busyfixin's Avatar
Yep, I can mail it, or I could probably meet you in Tustin area.
Old January 29th, 2014, 10:31 PM   #7
busyfixin
Balls Deep
busyfixin's Avatar
TTT Someone wants to make smoke clouds with this thing!
Old February 18th, 2014, 11:37 PM   #8
busyfixin
Balls Deep
busyfixin's Avatar
Kaboooom!!!
Old April 30th, 2014, 09:55 PM   #9
busyfixin
Balls Deep
busyfixin's Avatar
Bring it up
Old May 3rd, 2014, 07:38 AM   #10
wolfy
1997 TJ
wolfy's Avatar
In General any long gun can be mailed within the state by a nonlicensee (without an FFL)...
And "Registered Mail" is only a recommendation,NOT Required!
See below...
Q: May a nonlicensee ship a firearm through the U.S. Postal Service?
A nonlicensee may not transfer a firearm to a non-licensed resident of another State. A nonlicensee may mail a shotgun or rifle to a resident of his or her own State or to a licensee in any State. The Postal Service recommends that long guns be sent by registered mail and that no marking of any kind which would indicate the nature of the contents be placed on the outside of any parcel containing firearms. Handguns are not mailable. A common or contract carrier must be used to ship a handgun.
[18 U.S.C. 1715, 922(a)(3), 922(a)(5) and 922 (a)(2)(A)]
Link below...
http://www.atf.gov/content/firearms-...censed-persons
wolfy is offline
Page generated in 0.33373 seconds with 54 queries
