Ghetto idle switch - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 16th, 2014, 09:00 AM   #1
Lousypirate
Whoop Whoop
Lousypirate's Avatar
Default Ghetto idle switch
As I was driving to a few errands after work, I had a thought about running a switch to the run wire of my diesel.
The thought being that I could flip the switch and then be able to remove the key and lock the steering.
The Kernel (46 CJ2a)
Wow, i would lick those...
Old January 16th, 2014, 09:13 AM   #2
I suck cocks. Lots of them.
locally famous
Or just carry an extra key and lock the door?
Old January 16th, 2014, 09:14 AM   #3
8PTBUCK
I'm the dude, man
8PTBUCK's Avatar
What would be real purpose of this? I'm confused. So in case somebody wanted to steal your truck, they would only be able to drive straight? Lol
Old January 16th, 2014, 09:16 AM   #4
Bo's Cj 7
Bo's Cj 7's Avatar
I bought a remote starter and installed myself it does the same thing and I can start it from here, I think it was $39
Bo's Cj 7 is offline   Reply With Quote
Old January 16th, 2014, 09:24 AM   #5
wave_crusher
I'll Direc your TV
wave_crusher's Avatar
Wouldn't it be easier and better to hook up a keyless entry, then just keep the fob with you????
Old January 16th, 2014, 09:28 AM   #6
tom77cj5
tom77cj5's Avatar
A lot of keyless entry systems do not work when the vehicle is running
Old January 16th, 2014, 09:31 AM   #7
Mr. Beefy
BFT!
Mr. Beefy's Avatar
I bought a remote start for mine I press a button twice and I can pull the key.
When my truck has a key in the ignition you cannot unlock the doors with the button (Did away with keeping an extra key)
The remote start also gave me a turbo timer. lets the truck cool down for 3 minutes before shutting down.
Old January 16th, 2014, 09:34 AM   #8
Lousypirate
Whoop Whoop
How much you spend on yours?
Taking the key it would lock it in park too? Not just lock the steering. I could turn the key to off and remove. If the switch got turned off, it would just shut the engine down. When I get back to the truck, key goes in, put back to run, and turn the switch off.
A switch and a couple diodes are a hell of a lot cheaper than a remote starter... even though I would like one
Old January 16th, 2014, 09:34 AM   #9
8PTBUCK
I'm the dude, man
8PTBUCK's Avatar
That is a great feature. What remote start do you have?
Old January 16th, 2014, 09:39 AM   #10
Mr. Beefy
BFT!
Mr. Beefy's Avatar
I paid $300 for mine 2 years ago.
It's an Excalibur like these
http://www.sonicelectronix.com/cat_m...ote-start.html
Old January 16th, 2014, 12:08 PM   #11
wave_crusher
I'll Direc your TV
I actually did not know that. The two that I have put in my trucks have both worked when it was running.
...Might be because of my A+ awesome electrical skillzz...NOT!
Old January 16th, 2014, 12:10 PM   #12
Lousypirate
Whoop Whoop
try starting it with your remote start while it is running with your key then
Old January 16th, 2014, 12:11 PM   #13
wave_crusher
I'll Direc your TV
I don't have that fancy remote start...just keyless entry
Old January 16th, 2014, 08:33 PM   #14
Elusive
Elusive's Avatar
Just shut your truck off. Don't be the douche bag that thinks they have to leave their diesel idling while at the store, or at the fuel pump.
Elusive is offline   Reply With Quote
Old January 16th, 2014, 09:26 PM   #15
Lousypirate
Whoop Whoop
I only wanted to let it idle if I was running in the gas station for 3 minutes, geez.
Old January 16th, 2014, 09:35 PM   #16
koochman450r
koochman450r's Avatar
My ignition key is split and I can easily remove my key fob. So I remove the fob and lock the door. Mine is an 03 Chevy. The alarm doesn't set but it does lock the doors.
you won this battle.
Old January 16th, 2014, 09:40 PM   #17
koochman450r
Well you don't have to but I leave my gas car running just like my diesel. Less wear on the starter and stuff. Plus I don't shut my truck off till the egt reaches 300 or less. So I won't just pull in and shut it off hot. At that temperature the oil that sits in a hot turbo can boil/burn and leave residue in the turbo bearings and shorten the life. That's the main reason I leave my truck running.
Old January 16th, 2014, 09:56 PM   #18
caleb24v
RUMPELEDSTEELSKIN
Not sure what type of diesel you have but with my 24 valve Cummins you can get the edge programmer and set the turbo timer for up to 5 minutes. Shut off the truck, pull the key (timer will keep it running) go about your business, hop back in, turn the truck back "on" and away you go. That's what i do.
caleb24v is offline   Reply With Quote
Old January 16th, 2014, 09:57 PM   #19
caleb24v
RUMPELEDSTEELSKIN
I'm guessing you shut it off at stoplights too...
Old January 16th, 2014, 10:10 PM   #20
Lousypirate
Whoop Whoop
yup, 12 valve.
programmer
Page generated in 0.35263 seconds with 84 queries
