fuel tank build questions - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 12th, 2014, 10:38 AM   #1
mcreynrp
chevy4x4
mcreynrp's Avatar
Default fuel tank build questions
I am building my first fuel tank and was wondering if it needs to be vented into the tank or out of the tank. Motor is carbureted. It will not have a vented cap.
mcreynrp is offline   Reply With Quote
Old January 12th, 2014, 02:08 PM   #2
Tab
Tab's Avatar
Usually you'd mimic whatever set up the factory fuel system your using had. If it had a vented cap or a hose running up to the cap area to vent, then you'd make something similar. I pretty sure every type of system has some sort of vent or the pump will not be able to work.
Old January 12th, 2014, 02:21 PM   #3
lgottler
lgottler's Avatar
I'm not sure what you mean by vented in or out, but a roll over valve with a filter routed up high should vent your tank well.
lgottler is offline   Reply With Quote
Old January 26th, 2014, 12:58 PM   #4
mcreynrp
chevy4x4
mcreynrp's Avatar
ok thanks guys
Page generated in 0.14164 seconds with 35 queries
