Malls and Groceries - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 9th, 2014, 04:58 PM   #1
Ohhseven
Default Malls and Groceries
New to the forum. First time seeing it to be honest. I found it from an FB group. In any case, here is my junk.
Factory Specs:
2007 Jeep JK Wrangler Unlimited X
3.8L V6 SMPI Engine
4-Speed 42RLE Automatic Transmission
Bright Silver Metalic
Dark Slate Gray/Medium Slate Gray Cloth
AM/FM Single Disc CD/MP3 Radio (RES)
Deep Tint Sunscreen Windows
Build Specs:
Teraflex front lower control arms
Teraflex front 3-4" coil springs (1853202)
Teraflex rear 3-4" coil springs (1854202)
Teraflex VSS 9550 series shocks 3-4" lift (1545200)
Teraflex Front upper bump stops (953800)
Teraflex steel braded brake lines front 26" (4353310)
Teraflex steel braded brake lines rear 30" (4350310)
Performance Accessories 1 inch body lift
Yokohama Geolander M/T plus 38x13.50R17LT
Micky Thomson Sidebiter 17x9 4.5" bs
Rugged Ridge XHD front bumper
Smittybilt XRC rear bumper w/tire carrier
LoD Singnature Series Rock Sliders
EVO Sleeves and C2 gussets
Synergy Heavy Duty front ball joints
Synergy High Steer Drag Link
Synergy Front Track Bar Bracket
Synergy Heavy Duty Chromoly Tie Rod
Yukon Front Dana 30 5.13 Reverse Rotation Gears (YUKYG D30SR-513JK)
Yukon Rear Dana 44 5.13 Standard Rotation Gears (YUKYG D44JK-513RUB)
Nitro-Gear D44 35 spline chromemoly rear axles (NGA-AXD44JK-35-REAR)
Rear Dana 44 35 spline ARB Locker (ARBRD147)
Rear Dana 44 ARB black diff cover (ARB0750003B)
WARN HS9500i
Factor55 ProLink Loaded (00015-04)
K&N Replacement Air Filter (33-2364)
Superchips TrailDash
IPF 920H4 Headlight kit (IPFJK 920H-KIT)
LightForce 170 Striker (RMDL170HT)
Ridgid Industries D2 Diffused Rear Back-Up Lights
WalMart Budget Rock Lights
Daystar lower dash switch panel (RGD51151)
Daystar upper dash panel (KJ71020)
Mastercraft Grab Handles
Tuffy Security Conceal Carry Underseat Drawer
Cobra 29 LTD CB Radio
Firesik II Antenna
Cooltech ultramount CB antenna kit (JK07CTUMNT)
Cooltech versamount (JK07CTVERS)
CB antenna quick disconnect
Misch front arm rests (JAJK150)
Quadratec arm rest pad (55013.60X)
Welcome Distributing front grabars (1001)
ARB Jeep JK Wrangler air compressor and mounting bracket package (ARBJK-COMPRESSOR-KIT)
Ohhseven is offline   Reply With Quote
Old January 9th, 2014, 05:00 PM   #2
HVYRTFT
Reed my teef
HVYRTFT's Avatar
Nerd alert!
Old January 9th, 2014, 05:09 PM   #3
I suck cocks. Lots of them.
locally famous
Originally Posted by HVYRTFT View Post
Nerd alert!
No seat covers?
Old January 9th, 2014, 05:52 PM   #4
Andy456123
Guest
more pictures
Andy456123 is offline   Reply With Quote
Old January 9th, 2014, 05:59 PM   #5
jbsjunk
Little Member
jbsjunk's Avatar
Old January 9th, 2014, 06:06 PM   #6
scare-crow
the eskimo bro
scare-crow's Avatar
Send a message via AIM to scare-crow
You're so cool with your part #'s and lists.
Choke on and get bent.
scare-crow is offline   Reply With Quote
Old January 9th, 2014, 06:11 PM   #7
jbsjunk
Little Member
jbsjunk's Avatar
It does look like a grocery list. A check book ride.
Old January 9th, 2014, 06:14 PM   #8
curbdog17
Mini Van
curbdog17's Avatar
Sounds like a nice little build you got going there. Got any pictures of it?
Don't mind the hazing, these guys will grow on you.
Old January 9th, 2014, 06:14 PM   #9
caleb24v
RUMPELEDSTEELSKIN
He found it on FB!
caleb24v is offline   Reply With Quote
Old January 9th, 2014, 06:18 PM   #10
jbsjunk
Little Member
jbsjunk's Avatar
Steveo has a new hoopte?
Old January 9th, 2014, 07:03 PM   #11
firehawk
Live Action!
firehawk's Avatar
Straight up balla!
Old January 9th, 2014, 07:37 PM   #12
wave_crusher
I'll Direc your TV
wave_crusher's Avatar
Did you just have some pipe laid in your buttox?
Old January 9th, 2014, 07:37 PM   #13
fordbronco
the ocean called
fordbronco's Avatar
Shouldn't you have a larger tire size for mall crawling?
Old January 9th, 2014, 07:51 PM   #14
koochman450r
koochman450r's Avatar
Well this is pretty much every single jeep build. That's all jeep people do is open their wallets and order parts. So I'm not surprised. Unless they can't afford to order it so they make their own. .02
you won this battle.
Old January 9th, 2014, 07:52 PM   #15
jbsjunk
Little Member
jbsjunk's Avatar
Move to classics, or bin.
Old January 9th, 2014, 07:57 PM   #16
wave_crusher
I'll Direc your TV
I think this should be a sticky
Old January 9th, 2014, 11:28 PM   #17
scare-crow
the eskimo bro
scare-crow's Avatar
Since SS is not here....
Prepare your anus.
Old January 10th, 2014, 05:01 AM   #18
I agree.
Guys, you are over doing it. I'm glad all of you have something nicer.
Old January 10th, 2014, 05:12 AM   #19
bigbchevy
missmrgreenagain
bigbchevy's Avatar
I agree.
H.o.r.e
Old January 10th, 2014, 05:25 AM   #20
knaffie
knaffie's Avatar
Factory Specs:
3.8L V6 SMPI Engine
Build Specs:
WARN HS9500i
Firesik II Antenna
Welcome to the forum. Something is messed up in the code for you picture, so it isn't showing up.
Page generated in 0.50410 seconds with 84 queries
