D44 Steering - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 6th, 2014, 09:08 AM   #1
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Default D44 Steering
My dad is running steering like this
He is getting a lot of slop outta the bolt I think the knuckle is getting sloppy.
I've seen in the past a tapered bolt that he could put in place but I dont know where anyone has gotten them.
Old January 6th, 2014, 09:19 AM   #2
ckupq
Kitten I'm gonna eat you!
ckupq's Avatar
Put a flat top style high steer arm on the Pass side and make that thing double shear.
ckupq is offline   Reply With Quote
Old January 6th, 2014, 09:34 AM   #3
Mr. Beefy
BFT!
Mr. Beefy's Avatar
He does not have flat top knuckles and it's not worth changing as he is build a new 60 and 14 bolt...
I'm just looking for the tapered bolt.
Old January 6th, 2014, 10:16 AM   #4
Wramblerguy
Wramblerguy's Avatar
http://bcbroncos.com/store/product_i...roducts_id=770
3rd generation jeeper
Old January 6th, 2014, 11:11 AM   #5
ckupq
ckupq's Avatar
That's the reason I said Flat top style high steer. You could weld one on and plate the shit out of it.
He doesn't DD it does he?
Old January 6th, 2014, 11:47 AM   #6
BIGBEN
All out Idiot
BIGBEN's Avatar
Beefy
The problem I see is that the hole was probably drilled out for the bolt to go through the steering arm. If that is the case there won't be any taper to put that stud into. So you will have to remove and replace the knuckle to get one with a taper.
If you are going to remove the knuckle, I would just add an extra arm to the top to make it double shear. Run it till you guys get the 60 done and in.
Originally Posted by Stan View Post
My hope is that one day all women will realize just how well they could have it if they just shut their big fucking whining mouths.
BIGBEN is offline   Reply With Quote
Old January 6th, 2014, 11:53 AM   #7
Wramblerguy
http://www.ruffstuffspecialties.com/...INGACCESSORIES
Old January 6th, 2014, 12:35 PM   #8
koochman450r
koochman450r's Avatar
Originally Posted by Wramblerguy View Post
There ya go.
you won this battle.
Page generated in 0.26794 seconds with 47 queries
