fuse blowing, help me - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 4th, 2014, 05:44 PM   #1
sQUEAK003
Irish R&B Singer
sQUEAK003's Avatar
Default fuse blowing, help me
any advice. '01 pontiac aztek, blowing 40 amp starting fuse when trying to start. i've never ran into this problem to know how to fix it. starter maybe?
'09 "Sparkly Tan" Jeep Patriot
http://badges.fuelly.com/images/smallsig-us/306663.png
CLICK HERE TO GET RID OF ME
Originally Posted by PCK_4xCustoms View Post
cunt punt, it's like a reset switch for women.
sQUEAK003 is offline   Reply With Quote
Old January 4th, 2014, 05:55 PM   #2
Grassman
2jz specialist
Grassman's Avatar
are You Jumping It?
Old January 4th, 2014, 10:59 PM   #3
unclebeaner
can you hear the banjos?
unclebeaner's Avatar
starter or wire is melted. shoot me a pm if you need a hand im right up the road
Old January 5th, 2014, 08:19 AM   #4
sQUEAK003
Irish R&B Singer
sQUEAK003's Avatar
Not jump starting. Wife came home from work, 5 min drive. We went back out half an hour later and not even a click. crawled under to check voltage and had 12v at the starter and nothing at the solenoid. Jumped up to the fuse box and found a blown 40amp fuse. The only time I've blown that kind of fuse was with a starter that locked up and wouldn't crank and was after a second of trying. this is an instant blown fuse as soon as you touch the start portion of the key. I'm. going to pull the starter and get it checked. I'm thinking I may have an internal short in the solenoid. if not I have to find it in the wiring.
Old January 7th, 2014, 10:15 PM   #5
86scottsdalek10
86scottsdalek10's Avatar
I would agree with a faulty solenoid.
86scottsdalek10 is offline   Reply With Quote
Old January 8th, 2014, 12:50 PM   #6
davidkassie
davidkassie's Avatar
not entirely positive, but I believe there is issues with the a/c clutch shorting out causing this fuse to blow. not on any wiring diagrams, but I have seen something similar on other gm cars, simply unplug a/c compressor clutch and see if it blows, just an idea....
davidkassie is offline   Reply With Quote
Page generated in 0.14902 seconds with 41 queries
