loose steering - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 3rd, 2014, 09:27 PM   #1
mideerslayer
NEVER GIVE UP!
mideerslayer's Avatar
Default loose steering
I just picked up a 96 dodge ram 1500 4x4 and the steering wheel has a lot of movement.
I have not looked under it yet, but am I looking at a bad center link or idler arm or pitman arm?
When I turn right or left its fine, its when i am just driving straight there is a lot of movement.
Thanks for any input
Rich
mideerslayer is offline   Reply With Quote
Old January 3rd, 2014, 09:40 PM   #2
GREASYHANDS
GREASYHANDS's Avatar
Loose ujoint
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old January 3rd, 2014, 09:53 PM   #3
TJ/WILLYS
TJ/WILLYS's Avatar
Trac bar?
TJ/WILLYS is offline   Reply With Quote
Old January 3rd, 2014, 10:22 PM   #4
PinItToWinIt
PinItToWinIt's Avatar
My bet would be tie rod ends and or track bar.. My 3/4 ton had the same problem and both of these made the steering much tighter. I also replaced the steering box and though about doing the spring in the steering wheel shaft.. I also went with the newer style tie rods from a 98, might be worth looking in to..
PinItToWinIt is offline   Reply With Quote
Old January 4th, 2014, 12:26 AM   #5
michigan maniac
michigan maniac's Avatar
Dodge front ends suck!! Always parts going bad, If you plan on keeping the truck for a while use moog replacement parts they hold up the best and life time warranty, most dodge steering slop is from track bars and gear boxes worn out or need to be adjusted, I would look over the whole front end fix what's bad if any and adjust the gear box
Old January 4th, 2014, 05:28 AM   #6
Silver Bullet
Livin the American Dream
Silver Bullet's Avatar
It could be ujoint, ball joints, forties inner or outer, Trac bar, sloppy gear box, steering wheel components.
Your going to need a second set of hands to turn the wheel while your under it and see what is sloppy. Also put it in the air and check the ball joints.
Have fun. Or just spent about 800-1000 in parts and and 2 days labor to replace it all minus the gear box.
Silver Bullet is offline   Reply With Quote
Old January 4th, 2014, 06:19 AM   #7
I suck cocks. Lots of them.
locally famous
You should bash whoever sold it to you.
Old January 4th, 2014, 07:34 AM   #8
mideerslayer
NEVER GIVE UP!
grow up asshole. I bought it knowing the sloppy steering.
I posted looking for places to start looking once I get under there.
Thanks for the real responses.
Page generated in 0.25723 seconds with 47 queries
