LJ 5.3 BUILD THREAD PT 1 - Boatsides - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 24th, 2014, 09:09 AM   #41
Mr.Green
I can levitate!
Mr.Green's Avatar
But they are worth Street Cred, so its your call.
Old February 24th, 2014, 10:53 AM   #42
ryanclimbs
werocker
ryanclimbs's Avatar
Well the engine and electrical has been very well waterproofed to mil810 standards... Not worried about that ... And I figure it doesn't hurt to let the engine breathe as much as I can... In ultra 4 races you Often see rigs driving around without the hoods because they were having cooling issues... Doesn't hurt to have as much airflow as possible
JK-U Currie D60 RJIII's w/ARB's | Teraflex LCG | Mud Grappler 40x15.50x20's on Spyderlocks | Warn Dualforce 12K WINCH
Custom cage-rockers-body armour | WOODY's | passport plus lincoln on-board welder | S&W airlite 44 under the seat
ryanclimbs is offline   Reply With Quote
Old February 24th, 2014, 01:33 PM   #43
NightKrawler
KOH Jackhammer
NightKrawler's Avatar
If this is going to be used only for ultra4 races them you should be fine. Just kidding...mostly. Looks like you're making some progress. Looking forward to seeing it when it's finished.
Subscribe for more videos http://www.youtube.com/user/bult4mud/videos
http://www.youtube.com/channel/UCYL4kHv0JB5sOKlPALLHGTQ
--l ,[____],
l---L 0lllllll0-
()_) ()_)--o-)_) .......
NightKrawler is offline   Reply With Quote
Old February 24th, 2014, 02:06 PM   #44
What length coilovers did you put up front? Can you post more pictures of the 5.3 in position with driveshaft clearance and skid plate/oil pan location please?
Old February 24th, 2014, 02:55 PM   #45
ryanclimbs
werocker
ryanclimbs's Avatar
Ha ha no I'm just trying to do everything is good as I can and it's been very helpful to get feedback from here and other forums!!!
Old February 24th, 2014, 02:56 PM   #46
ryanclimbs
werocker
ryanclimbs's Avatar
It's got 14 inch coil overs front and rear and I will try to post up some photos when I get a chance but I leave for Colorado tonight so it may be a week or so!
Old February 24th, 2014, 04:15 PM   #47
ryanclimbs
werocker
ryanclimbs's Avatar
Put a few more braces and gussets in today
Old February 24th, 2014, 04:45 PM   #48
There's no reason to have to cut the hood for 14" shocks but it's all personal preference.
Old February 24th, 2014, 04:53 PM   #49
ryanclimbs
werocker
ryanclimbs's Avatar
Not sure how closely you have been following this but the fenders are moved up 4 inches from the stock position for a super low center of gravity and 4 inches more of up travel... So in order to cycle correctly I do need to put the shocks through the hood!
Old February 24th, 2014, 04:54 PM   #50
bbaXJ
Yooper In Training
bbaXJ's Avatar
That's a pretty broad statement to be making. That's like claiming you can't break a Dana 60 with 35" tires. It all depends on ride height, shock location, shock height, and travel settings.
I agree he didn't have to based on the pics, but I prefer that look too. I run 14" shocks, but mine are ProFender, which run longer than most. I also have mine set up pretty low with maximum uptravel, and even with a 1" body lift I have to trim the hood. I *might* have been able to drop them down enough to clear the hood, but then the bottom spring cups would get dangerously close to the kingpin caps under flex.
Old February 24th, 2014, 04:58 PM   #51
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
Originally Posted by bbaXJ View Post
Here's how I braced between the floor plate and lower body crossmember underneath the A pillar. It's just a piece of tube to take the load. There are other ways to do it, but this is the basic idea to transfer the load to the rigid plate, rather than just hoping the sheetmetal doesn't crush together.
that front cage mount would do nothing in a roll over
Old February 24th, 2014, 04:59 PM   #52
hosejockey4506
Visiting Admin
I quoted the wrong picture, but all it is going to do is tear right off the frame
Old February 24th, 2014, 05:01 PM   #53
bbaXJ
Yooper In Training
bbaXJ's Avatar
I'm not a fan of how horizontal the frame tie-in bar is, but that's as flat as I could get it. Some creative gusseting will help that. I don't see a problem with the rest of it, it's supported and transferring the load as it should. Running some alighment plugs inside the sleeve would help too. It's not ideal, but it'd sure as hell "do something in a roll over"
I figured as much. I agree, the horizontal mount isn't great. But between the body mounts and cage tie ins, I think it adds quite a bit of strength and support. But I do agree that it needs more gusseting so it doesn't act as a pivot point in a hard roll. That's an easy addition for the owner of the rig(he hasn't even finish welded the fenders or painted the cage yet, so plenty of time to beef it up before wheeling)
Old February 24th, 2014, 05:06 PM   #54
I'm fairly familiar with LCG Tj's It's not a stretch to get them under the hood unless, maybe, you have emulsion shocks which are hella long. You can see from his picture that he only needed to cut the hood because of how he mounted the tabs on the hoops. You did it out of preference. Some people say it looks cool. Some people say it looks like poor planning. It's all personal preference.
Old February 24th, 2014, 07:25 PM   #55
ryanclimbs
werocker
ryanclimbs's Avatar
Well I wouldn't to say it's poor planning... Ha ha, I do like the way it looks... But in this case it was Because that's the place where I wanted the top of the coilovers to mount... And I couldn't have moved the hoops any closer to the engine or I wouldn't be able to pull the engine... If I mounted the coilovers farther outboard I would've had tire clearance issues
Old March 9th, 2014, 01:18 PM   #56
ryanclimbs
werocker
ryanclimbs's Avatar
Finish setting up the rear end put the battery in... Almost ready for paint!
Old March 10th, 2014, 02:24 PM   #57
ryanclimbs
werocker
ryanclimbs's Avatar
Everything works great!!!
Old March 10th, 2014, 03:59 PM   #58
Are your coilover mounts welded to the inner C's? What material are those? No wonder you had to go through the hood Always good to see something out driving I'd like to see how you routed your front driveshaft and engine mounts/skids if you get a chance
Old March 10th, 2014, 04:39 PM   #59
hellspawn
hellspawn's Avatar
Looks good
hellspawn is offline   Reply With Quote
Old March 10th, 2014, 04:45 PM   #60
ryanclimbs
werocker
ryanclimbs's Avatar
Feva4u
Yes I did mount to the C's in order to give it the widest stance it is a CRD 60 housing & the C's are gigantic... I have a friend that did this on his buggy and I was hesitant and he has proven to me that it works very well...
Here are some photos of the skid plates and
Page generated in 0.42490 seconds with 83 queries
