Dryer problems - any advice welcome *SOLVED!* - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 27th, 2013, 07:13 AM   #21
Easy_E
Web Wheeler !
Easy_E's Avatar
Originally Posted by swampjeep View Post
manual online said 7 3/4 ft max length
It should say minus x amount of length per elbow ? When I run ours I believe at six feet and two elbows I was at the limit ?
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Easy_E is offline   Reply With Quote
Old December 27th, 2013, 07:21 AM   #22
swampjeep
Swamp Stomper
swampjeep's Avatar
so I'm guessign the 7 3/4 ft is for flex type, then these other charts are for rigid type?
ID:	113136   Click image for larger version
swampjeep is offline   Reply With Quote
Old December 27th, 2013, 07:26 AM   #23
Herezja
Herezja's Avatar
I worked on this thing again last night. I removed the cheapy flex pipe and replaced it with semi-rigid. Before I did that, though, I shoved my arm into the vent to see if I could feel anything and about cut my hand off from a sawzall blade sticking up through the seem of the vent. Nice! So I pushed the sawzall blade down through the vent and let it fall into the crawlspace, installed the new vent pipe and ran the dryer...still same problem. So...down into the crawlspace I went. I checked out the vent and found it had gotten disconnected, of course at the one place where there were so many pipes in the way I had to be a circus contorsionist to work on it. So after about 1 1/2 hours of bending in un-natural ways and cussing enough to make a truck driver blush, I managed to get the vent reconnected. Went to check the dryer again, thinking I had FINALLY solved the issue. This time, I put my GL4x4 sweatshirt in there (odd that this is what I had to test the dryer), since it was damp from the wash earlier in the day and fired up the dryer. The "Check Vent" light came on AGAIN, but it seems to actually be heating up properly now. Granted...I only put one damp sweatshirt in there. My wife is going to run a full load through today and see what happens...that will be the real test.
Thanks for the suggestions everyone, but to be honest I am done with this stupid dryer and am throwing in the proverbial towel. I have wasted enough time, energy, and good cuss words (usually reserved for the Jeep) at this point. If it is still not working, I am calling an appliance repair guy/gal. Any reccommendations on a good one in the Saginaw/St Charles/Hemlock area?
Herezja is offline   Reply With Quote
Old December 27th, 2013, 07:32 AM   #24
Herezja
Herezja's Avatar
Attachment 113135
Thanks. I went through all this in the manuals. My vent run resembles the bottom exhaust installation in the first diagram, with one exception - once it is under the floor (pictured) it makes a 90 to the right and runs across the crawl space to outside...maybe about 4 - 4 1/2 feet. So...the whole run is probably 6-7 feet total with 3 90s.
Old December 27th, 2013, 07:55 AM   #25
FyrFyr
FyrFyr's Avatar
You might want to looking at installing an in-line booster fan. Menard's sells them. I had similar issues with little bit longer duct run. The booster fan fixed it.
FyrFyr is offline   Reply With Quote
Old December 27th, 2013, 08:03 AM   #26
Herezja
Herezja's Avatar
Interesting. Never heard of such a thing. Does this install in the vent somewhere?
Old December 27th, 2013, 08:08 AM   #27
tsaguy
Semper Fidelis
tsaguy's Avatar
Your venting, although clean and clear, has too many bends. The dryer doesn't have the velocity to push the air out. You must allow as straight a run as possible for your dryer to work properly. If needed, as mentioned above, you should install a helper fan, or booster fan.
Although a bend doesn't seem like much, a 90-degree bend to the simpler exhausting of a dryer is restrictive.
Calling an appliance repairman to resole this may frustrate your wallet.
If I were you, I would calculate moving the dryer to a new position with as little friction as possible since you must take into thought the gas line. Use PVC if possible for your exhaust.
Good luck to you, I know this can be frustrating.
tsaguy is offline   Reply With Quote
Old December 27th, 2013, 08:10 AM   #28
Herezja
Herezja's Avatar
I am going to look into a booster fan.
Old December 27th, 2013, 12:50 PM   #29
wrath
Project Antitube
wrath's Avatar
Send a message via AIM to wrath
Try opening a window in the same room as the dryer. Chances are the fan can't generate enough vacuum to provide enough flow because wherever it is located is sealed too tight.
In my old house my dryer pushed through six 90s and almost seventy feet of pipe but it wouldn't function with the bathroom fan or the range hood running.
wrath is offline   Reply With Quote
Old December 27th, 2013, 01:12 PM   #30
kickstand
circling the drain
kickstand's Avatar
clothes line
Old January 2nd, 2014, 08:27 AM   #31
Herezja
Herezja's Avatar
Looks like the dryer issues are solved. What did I do?? Well...hell if I know!
After I reconnected the vent in the crawlspace the "Check Vent" light was still coming on. I even unplugged the dryer and let it "reset" and it was still indicating that there was a vent issue. I went to work the next day and my wife reported to me throughout the day that the dryer was working fine, but the light was still on. Feeling beaten by an appliance, I gave up and made an appointment to have a Whirlpool Tech come take a look. That was Friday. We did a couple more loads of wash on Saturday morning and miraculously the light went out...and stayed out. Did nothing different. Hell...I didn't even touch the thing again after calling for a service request. When Whirlpool called on Saturday afternoon to confirm the timeframe for the appointment (scheduled for Monday), I canceled. Been keeping an eye on the dryer ever since and it is working perfect now.
I am pretty convinced that it was the disconnected vent piece in the crawlspace, but have no idea why it took almost 24 hours for the light to finally turn off. Oh well...it is working fine now and that's all that really matters to me
Thanks for all the advice. If this issue comes back, I am going to look into adding a vent fan.
Old January 2nd, 2014, 01:21 PM   #32
Wehan
Wehan's Avatar
Light burnt out lol
Wehan is offline   Reply With Quote
Old January 2nd, 2014, 01:25 PM   #33
swampjeep
Swamp Stomper
swampjeep's Avatar
I have heard it said before that all problems, when left alone, have a way of fixing themselves.
Old January 2nd, 2014, 01:32 PM   #34
Herezja
Herezja's Avatar
Not true...haven't touched my Jeep in a few months and it still runs like crap.
Maybe I just haven't left it alone long enough?
Page generated in 0.44433 seconds with 65 queries
