Dryer problems - any advice welcome *SOLVED!* - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 26th, 2013, 10:22 AM   #1
Herezja
Herezja's Avatar
Default Dryer problems - any advice welcome *SOLVED!*
Any dryer gurus on here? I need a little advice...
So, we just moved to a new house and I have been battling my dryer for a bit. We moved our washer and dryer with us (since they were only a year and half old). Once we got to the new house, I converted the dryer from natural gas to propane. The conversion went fine and the dryer was all hooked up. The dryer worked perfect at our old house, but at our new house it is having issues. The "Check Vent" light comes on during the programable cycles (works fine on "timed dry" and the dryer is taking FOREVER to dry clothes (it is barely heating up). I have checked the vent outside and there is plenty of hot air coming out and the flap on the vent moves freely.
I started troubleshooting the thing the other day. I disconnected the dryer from the vent and dried a load of clothes....dryer worked PERFECT! So, I ran my shop vac through the vent and then ran a pipe/drain snake through the vent to loosen anything up that might be stuck in there. I then ran the shop vac through it again on suck and then on blow. So, I hooked the dryer back up and am still having the same issue.
So...the problem has to be with the vent, since the dryer works perfectly fine when disconnected, right? I went through all the manuals that came with the dryer and have dug around online. I haven't really come up with anything except replacing the flex hose between the dryer and the vent with a rigid pipe connection (as reccommended in the manual). In all honesty, that is the only thing I have left to try).
Anyone have any ideas or run into something like this? I am kinda out of ideas on this thing and my wife is about to go nutso on me and the dryer if I don't get this thing working right.
Herezja is offline   Reply With Quote
Old December 26th, 2013, 10:50 AM   #2
TJJEEP
TJJEEP's Avatar
Send a message via AIM to TJJEEP Send a message via MSN to TJJEEP
I see where you cleared out your vent but did you try to clear the outlet of the dryer back into the dryer to the lint catcher?
There has to be some sort of flow sensor that tell the dryer that the vent is blocked. Maybe that is dirty or stuck?
I feel you on the necessity of having a working dryer. Ours went out when my wife was home with our second kid after birth and it was like hell around the house until we got a new one.
TJJEEP is offline   Reply With Quote
Old December 26th, 2013, 10:53 AM   #3
Herezja
Herezja's Avatar
I will take a look at that, but if this was the case, why would the dryer work perfectly fine disconnected from the vent? I literally had it venting into the laundry room...fogged up every window in the house.
Old December 26th, 2013, 10:57 AM   #4
TJJEEP
TJJEEP's Avatar
Maybe the bends in the venting were enough back pressure to make the sensor malfunction.
This is probably unrelated to yours but my electric dryer's plug was faulty. It took me a while to find but the voltage to the plug went from 80 -220. Sometimes it would work perfectly, sometimes it wouldn't. The dryer always spun but sometimes it wouldn't heat up. 80V was enough for it to turn on and spin but not kick on the heat. This is unlikely your issue but maybe yours has a voltage sensor and will not kick on the heat if it doesn't get proper voltage and through my troubleshooting I always bumped and moved things around like the plug and it worked for a bit.
Old December 26th, 2013, 11:01 AM   #5
Herezja
Herezja's Avatar
That is what I am beginning to think. The flex pipe the installers put on the dryer is really long. Although it is compressed down, I have heard a too long piece of flex on the dryer can cause problems...compressed or not. That is kind of why I am leaning toward replacing it with a piece of 4" rigid.
Interesting. Never thought about an intermittent voltage issue. I will check that out when I get home tonight.
Old December 26th, 2013, 11:19 AM   #6
swampjeep
Swamp Stomper
swampjeep's Avatar
I would suggest not using the "flex" type drier hose, get real straight stuf, and elbows, the flex stuff will not flow as well, so if you are having flow issues when attached, I would bet that is your problem. Also if you have any horizontal sections, make sure it is still slightly angled and not 100% horizontal.
swampjeep is offline   Reply With Quote
Old December 26th, 2013, 11:32 AM   #7
Herezja
Herezja's Avatar
I am heading to Home Depot at lunch time today to pick up a peice of rigid. I am hoping you are right and this is the problem. It is what I have been suspecting at this point as well.
Old December 26th, 2013, 11:54 AM   #8
TJJEEP
TJJEEP's Avatar
I would think if there is plenty of hot air coming out the current vent on the outside, it would be a sensor related issue.
What make and model of dryer?
Old December 26th, 2013, 12:02 PM   #9
Herezja
Herezja's Avatar
It is a Whirlpool Cabrio Platinum
Sent from my DROID RAZR using Tapatalk
Old December 26th, 2013, 02:45 PM   #10
Kane
Got Jeep?
Kane's Avatar
1) Burn down house (to make sure ALL problems are gone)
2) Build new house
3) Buy new dryer
4) Have it professionally installed
5) Enjoy perfectly working dryer system!
Kane is offline   Reply With Quote
Old December 26th, 2013, 02:54 PM   #11
Herezja
Herezja's Avatar
2) Build new house
3) Buy new dryer
4) Lay some pipe!
5) Have it professionally installed
6) Enjoy perfectly working dryer system!
fixed it for ya
Old December 26th, 2013, 07:24 PM   #12
Bow_Extreme
Bow_Extreme's Avatar
Great, installing my Cabriolet platinum tomorrow. I hope I don't run into the same issue.
Bow_Extreme is offline   Reply With Quote
Old December 26th, 2013, 07:42 PM   #13
tonka toy
It's got a HEMI!
tonka toy's Avatar
Put about 20' of 3/8's log chain in dryer turn it on high and let it run for no less then 45 min but no longer then 55 min. It will shake out anything that may be blocking the airflow.
Always missed, Never forgotten
FullSize4Life
08' 4door JK 5.7 hemi, auto, atlas and tons
2012 F350 6.7 PSD CC shortbox
tonka toy is offline   Reply With Quote
Old December 26th, 2013, 07:45 PM   #14
Immortal
NO RELIGION WAT!
Immortal's Avatar
Get a new woman!!
Old December 26th, 2013, 08:02 PM   #15
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
Your vent is clogged...I had the same problem. I cleaned it the best I could, in the end I had to run a new one
Old December 26th, 2013, 08:28 PM   #16
fsumotorhead
N8KVB
fsumotorhead's Avatar
I disassemble and vacuum mine about every year and a half or so, wife starts to bitch it takes too long to dry, and it's usually full of lint in there.
Old December 26th, 2013, 09:30 PM   #17
Jiveturkey3
Jiveturkey3's Avatar
Does your dryer have a beefweigh attachment?
Jiveturkey3 is offline   Reply With Quote
Old December 26th, 2013, 11:25 PM   #18
Denton
Brush Yo Teeth!
Denton's Avatar
If it didn't work when the vent was disconnected, I would say moisture sensor.
Seeing that it did function properly with vent disconnected, It must be your vent
Denton is offline   Reply With Quote
Old December 26th, 2013, 11:36 PM   #19
Easy_E
Web Wheeler !
Easy_E's Avatar
How long of run and how many elbows ? There is a maximum run length that is shortened for every elbow. It should give this in the manual.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Easy_E is offline   Reply With Quote
Old December 27th, 2013, 08:00 AM   #20
swampjeep
Swamp Stomper
swampjeep's Avatar
manual online said 7 3/4 ft max length
Page generated in 0.48921 seconds with 83 queries
