Anybody make a "plug & play" electric fan for 2nd gen Rams? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 25th, 2013, 06:08 PM   #1
Ready4Wheelin
Ready4Wheelin's Avatar
Default Anybody make a "plug & play" electric fan for 2nd gen Rams?
So, as per my previous thread about my ram not running over 150 degrees, I've discovered that the fan clutch, which is only about 8 months old, is not working properly. I've never liked engine clutch fans, so I'm wondering if anyone has ever seen or installed a complete electric fan kit that is pretty much bolt on and plug & play? Something that fits my radiator, moves enough air, and a sensor and relay harness that taps right into the cooling system snd does everything automatically. Thanks!
Ready4Wheelin is offline   Reply With Quote
Old December 25th, 2013, 06:16 PM   #2
Ready4Wheelin
Something like this, but about $500 cheaper
http://www.summitracing.com/parts/pr...model/ram-2500
Old December 31st, 2013, 12:58 PM   #3
dmkx3
grave digger
dmkx3's Avatar
I want to do the same thing on my 2012 ram.
dmkx3 is offline   Reply With Quote
Old December 31st, 2013, 03:30 PM   #4
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
I find it hard to believe that a faulty fan would keep your motor from ever getting over 150*. If your thermostat is working correctly you are never even circulating coolant through the radiator. The only thing the fan is doing is blowing more air over the motor itself. Have you tried removing the fan and running the motor to see if it warms up like it should?
Old January 1st, 2014, 04:59 PM   #5
Ready4Wheelin
Discovered the t stat and fan clutch are both bad. I've never cared much for engine fans anyway, still would like to put an electric setup on it.
Page generated in 0.30889 seconds with 38 queries
