2000 Ram 360 gas won't get over 150 degrees? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 24th, 2013, 10:40 AM   #1
Ready4Wheelin
Ready4Wheelin's Avatar
Default 2000 Ram 360 gas won't get over 150 degrees?
I have a 2000 Ram with the 360 gasser in it, no matter what I do I can't get the engine temp over 150 degrees. Put a 190 degree thermostat in it and flushed the system last year, didn't make much difference. Have to run it with the radiator completely blocked at ambient temperature below 40 degrees to get it up to about 170-190 and the heat is ok. Now, with the radiator completely blocked, it barely gets to 150 and the heat sucks! I know it's only 13 degrees out, but last winter in the same temps I could get it to 170 with the rad completely blocked. Ideas?
Ready4Wheelin is offline   Reply With Quote
Old December 24th, 2013, 10:47 AM   #2
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
Buy another new stat. They are cheap, easy to install and sometimes they are junk right out of the box. I figured this out after some very frustrating issues with my jeep.
Old December 24th, 2013, 10:51 AM   #3
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
You can even test your thermostat with a thermometer and a pot of water on the stove to see when it opens.
Old December 24th, 2013, 11:28 AM   #4
Ready4Wheelin
Thanks guys! Yeah, I was thinking t stat again, just don't feel like messing with it in this cold weather. The housing is a PITA to get to. I've got time to mess with it after xmas, thought maybe I was missing something in the meantime.
Old December 24th, 2013, 11:31 AM   #5
rammanriley
rammanriley's Avatar
Ive found that on the housing if you cut off the tab that says "front" it will allow you to sneak it out without taking the alt or a/c comp off. Cleaning the gasket surface is still a pain in the ass tho. Also is that a digital temp reading or just what the cluster says?
96 Ram 1500 ECSB 5.9l v8 4x4 On 35's
13 Dart Aero (turbo go fast)
rammanriley is offline   Reply With Quote
Old December 24th, 2013, 11:36 AM   #6
Ready4Wheelin
That's what the dash gauge reads, and it's gotta be close because the heat in the cab sucks!
Old December 24th, 2013, 01:05 PM   #7
Rob the plumber
The 318 in my ZJ is kind of a biatch too. It's all nestled in there.
Old December 24th, 2013, 02:50 PM   #8
firehawk
Live Action!
firehawk's Avatar
If your radiator is clogged so it your heater core.
Flush them out or replace them.
Old December 26th, 2013, 05:28 PM   #9
Cool parts peddler
Ironman Offroad's Avatar
I would check actual engine temp..
I have seen many gauges off by 30 to 40 degrees.
Flush the heater core with a garden hose both ways till it runs clear.
Old January 1st, 2014, 05:04 PM   #10
Ready4Wheelin
Discovered the t stat and fan clutch are both bad. Broke out the IR temp gun, reads between 126 - 134 when taken on the rad tank, hoses, and t stat housing. Fan clutch mysteriously decided to unlock the other day too, but is locked up again.
So, t stat, about 1 year old
Fan clutch, about 8 months old
Both bad already. Doesn't anybody make quality replacement parts anymore?
Old January 1st, 2014, 05:11 PM   #11
snocross2xtremes
snocross2xtremes's Avatar
the dealer
Old September 7th, 2014, 08:27 PM   #12
Dwysywd
Dwysywd's Avatar
And I quote...
. Mainly the sometimes they are junk i that out of the box. Test it before you install...see test instructions above. Next, if you have the choice to buy a $50 part made in Shrilanka or Mumbai, or $176 part made in the USA, buy the better part!
Really, not much more to say than that! Do that first... Even I'd they dont Need it. This is a easy way to eliminate easy stuff on the CHEAP.
Don't trust the dealer... I work in automotive with dealers... They usually don't have your best interest in mind.
Dwysywd is offline   Reply With Quote
Old September 8th, 2014, 04:56 AM   #13
Toivo
Feel lucky?
Toivo's Avatar
Originally Posted by Dwysywd View Post
And I quote... . Mainly the sometimes they are junk i that out of the box. Test it before you install...see test instructions above. Next, if you have the choice to buy a $50 part made in Shrilanka or Mumbai, or $176 part made in the USA, buy the better part!
You are a fucktard. Some dealers may be shitty, but most genuinely care. There is too much money at stake to not care nowadays.
Page generated in 0.29169 seconds with 62 queries
