99 Kawasaki prairie problem - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 22nd, 2013, 05:34 PM   #1
muddinman56
blood,sweat and beers
muddinman56's Avatar
Default 99 Kawasaki prairie problem
I have the idle problem it won't run with any thing less then full choke went through the carb nothing wrong there air inlet tubes are fine heads fine the only problem is the muffler is rusted and has one big hole in it would that really cause my problem?
Iv looked on Google and really haven't found what I needed
Old December 22nd, 2013, 05:54 PM   #2
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
Vacuum leak, clogged carb, a whole host of things could cause it
Old December 22nd, 2013, 07:24 PM   #3
muddinman56
But the thing is that it's not the carb cleaned it.
No cracks or cuts in any lines.
Not bad gas or dirty peacock cleaned it.
Not a bad plug.
No cracks or leaks of any kind on the head like some people said to check via google.
The only thing is the muffler has a nice rust hole in it
Old December 22nd, 2013, 07:57 PM   #4
firehawk
Live Action!
firehawk's Avatar
Not a bad plug.
Must be the problem then.
Old December 22nd, 2013, 07:59 PM   #5
Christmas Cookie
I can tell you that your carb might not be clean...I took me eight tries to get my trx carb clean and that was running it through an ultrasonic cleaner...if you don't have a vacuum leak then your idle circuit is clogged as well as your air screw passage
Page generated in 0.23695 seconds with 38 queries
