'93 Ford ranger 4x4 NOW WORKING! beater w/ a heater - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 18th, 2013, 02:55 PM   #1
Lynxer
Lynxer's Avatar
Default '93 Ford ranger 4x4 NOW WORKING! beater w/ a heater
93 ranger, v6, 4.0 If I remember right...
"SPLASH" reg cab, stepside short box.
auto tranny
auto hubs
160k miles
16" ford rims milled to fit ranger hubs
Runs/drives/heat blows hot on high. reliable beater.
The bad:
Oil dipstick broken off.. rusted out and snapped off. Pinched it.
Cab corner/front bumper rust. Its a mich truck!
front leaf hangers are going, one side has some angle welded on.. $30 each brand new... IF I find the time they may get fixed.
shifts a little hard from 2nd to 3rd, if you gun it in OD.
ghetto lift, coil spacers, and explorer? leafs
tires are crap.
drivers seatbelt buckle is stuck open.
$1200, or trade for ?
call/txt-989-817-six40six
Bad leaf mount:
Bad cab corners:
Bumper rust:
Lynxer is offline   Reply With Quote
Old December 18th, 2013, 08:59 PM   #2
Bones
Bones's Avatar
does the 4wd work? that is pretty much exactly what I am looking for
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old December 18th, 2013, 09:17 PM   #3
Lynxer
Lynxer's Avatar
Light is out, not sure if its working?
I will try and look at it tomorrow.
Worked over the summer, light and 4wd.
Old December 19th, 2013, 01:45 PM   #4
Lynxer
Lynxer's Avatar
Messed with the 4x4 on my lunchbreak.. turned out to be a loose connector on switch!
All fixed, and 4x4 is working as it should!
Old December 20th, 2013, 08:29 AM   #5
Lynxer
Lynxer's Avatar
Drove the truck around town yesterday while I ran errands.
4hi and 4lo are working great.
Front coil spacers causing pos. wheel camber.. Needs radius arm drops, or a REAL lift installed.
Overall the body is better than most! even with cab corner rust.. there are no major boo boo's on the body.
TRADE for full size truck? other 4x4's? jeep? ENCLOSED trailer 10'+?
pair of '95+ sleds?
Old December 20th, 2013, 06:55 PM   #6
chris1044
chris1044's Avatar
Frame straght? Is it rusted (structural, not surface) at all in the front leaf-shackle area? Hows the interior? Front end tight? Is the rear lifted, and if so how (does it have blocks other than the factory ones with the bump stop or shackles)?
Old December 20th, 2013, 10:51 PM   #7
Lynxer
Lynxer's Avatar
Frame is straight. Front leaf mounts will need replaced.. frame is not rusty just mounts. Bolt on fix.
Interior is OKAY, drivers seat is flat and dirty. The rest should clean up.
Not 100% sure what rear leafs are out of.. but it has the stock lift block with bump stop under them?
Truck is something between 4" & 6" lift.
Old December 23rd, 2013, 03:48 PM   #8
302sploder
302sploder's Avatar
pics of the rust and interior?
302sploder is offline   Reply With Quote
Old December 26th, 2013, 08:28 AM   #9
Lynxer
Lynxer's Avatar
Been out of power since saturday....
Txt for pics.
Old January 8th, 2014, 11:17 AM   #10
Lynxer
Lynxer's Avatar
Ttt. Still here.
Trades?
Old January 9th, 2014, 07:32 PM   #11
Lynxer
Lynxer's Avatar
price drop: 1200
Prefer a trade, might just find some tires and wheel it this spring.
Page generated in 0.25741 seconds with 56 queries
