1978 F250 Crew Cab; project "Eleanor" - Page 7 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 11th, 2014, 02:58 PM   #121
adamrz
Zombie Hunter
adamrz's Avatar
Default Semi serious question to the build
for those that are reading this, been contemplating something on the truck. Looking for some input.
Keep in mind the truck will serve several purposes (listed in order):
1. daily driver
2. recreational trailer puller
3. weekend camping/mountain biking/overlanding/general weekend adventure truck
The question is this:
To run a dually set up or to not run a dually set up?
Keep in mind this will be lifted (8" total), running 37's (I think), and will have a short bed box.
Thoughts?
adamrz is offline   Reply With Quote
Old June 11th, 2014, 03:12 PM   #122
Lousypirate
Whoop Whoop
Lousypirate's Avatar
dually will be awfully wide to do some of the off highway exercises...
If you aren't pulling enough to require the extra tires on a regular basis, I'd leave it a singly.
Old June 11th, 2014, 03:47 PM   #123
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
^ I'm with this guy.
Besides, dually just means another $500. in tires.
RIP FULLSIZE4LIFE
Old June 11th, 2014, 04:03 PM   #124
adamrz
Zombie Hunter
adamrz's Avatar
this is true. and that's a lot of beer money right there...
Old June 11th, 2014, 04:31 PM   #125
Lousypirate
Whoop Whoop
beer, fuel, and titties.
Old June 11th, 2014, 06:17 PM   #126
Barnhartal
Barnhartal's Avatar
My current truck is a drw. For towing there is nothing else better. Id go coast to coast with it with any load. For everything else and I mean everything, it flat out sucks! Even trips to the lumbar yard i feel its a hindrence.
Barnhartal is offline   Reply With Quote
Old June 15th, 2014, 12:11 AM   #127
adamrz
Zombie Hunter
adamrz's Avatar
Another tech question for those reading;
I am planning to run 37 inch tires, with a 17 or 18 inch rim. Looking at the axles. Question; gear ratio?currently running 4.10's. Would 5.13 ratio be too much for a DD with overdrive that's a diesel with that tire set up?
I know it will work, but I would like to still run the highway without eating 8mpg.
Old June 15th, 2014, 02:05 AM   #128
turtleturtle
turtleturtle's Avatar
Just my 2 cent on gears. I have two 96 7.3's crew cabs, long beds, 4x4's one has 3.55 other 4.10 gears both have 33 " tires running 70-80 mph is to much with the 4.10 , with 37's I would stay with 4.10. These 7.3 make enough low end you would be fine.By the way I run 6 position chips (TS) Swamps tune on one and a generic tune on the other, simple and inexpensive $225.00 ea. and Baby Swamps injectors just because they needed replaced $1100.00 set. They both run great. 5 years plus and almost 300,000 on ea truck. I built a 78 CC 24 years ago with a 460 loved that truck and was a great hauler. YOURS Will be sweet GOOD job
turtleturtle is offline   Reply With Quote
Old June 15th, 2014, 07:40 AM   #129
Barnhartal
Barnhartal's Avatar
Agree with the above. With 37s the max I would run would be 4.30's. Little extra power from engine and you'd be fine with 4.10's.
Old June 15th, 2014, 07:45 AM   #130
Barnhartal
Barnhartal's Avatar
When you do injectors not if but when go with either swamps or PIS. Spend the money and do at least a 175/80's. I would really consider going even bigger. Your engine has forged rods vs pmrs in the newer ones so you at least dont have to worry about that.
Old June 16th, 2014, 08:39 AM   #131
adamrz
Zombie Hunter
adamrz's Avatar
Thanks for the information. I will definitely look into as described. Can't wait to get the truck back to continue on this project.
Old June 16th, 2014, 08:40 AM   #132
adamrz
Zombie Hunter
adamrz's Avatar
Thank you. Any and all information is much appreciated.
Old June 16th, 2014, 05:47 PM   #133
Grassman
2jz specialist
Grassman's Avatar
Im not an "expert" but have a true passion for 7.3 powerstrokes. If I can help in anyway let me know.
guessing from location and what you have as an avatar, did you run trec? and have a cummins powered chevy?
Old June 16th, 2014, 05:47 PM   #134
Grassman
2jz specialist
Grassman's Avatar
oh, and subscribed!!
Old June 16th, 2014, 08:07 PM   #135
Lousypirate
Whoop Whoop
Adam, sick with 4.10's... if you get it done and don't like it, you change then.
I had 3.55 and ~32's on my 12 valve. I almost wished it was higher. I didn't do much towing with it.
Old June 16th, 2014, 08:30 PM   #136
Barnhartal
Barnhartal's Avatar
Co drove for the rig in my avatar. The 12v chevy is my buddys "small" tow rig. lol.
Old June 16th, 2014, 10:27 PM   #137
Grassman
2jz specialist
Grassman's Avatar
sweet, i love joes truck.
Old July 10th, 2014, 07:00 PM   #138
adamrz
Zombie Hunter
adamrz's Avatar
Default progress
Much progress made in regards to Eleanor. The shop mocked in the motor, got the transmount situated, and is now making the mounts.
Its like it was made to fit in there.
Old July 10th, 2014, 07:03 PM   #139
adamrz
Zombie Hunter
adamrz's Avatar
Old July 10th, 2014, 07:04 PM   #140
camoII
camoII's Avatar
Looks nice!
camoII is offline   Reply With Quote
Page generated in 0.32048 seconds with 83 queries
