1978 F250 Crew Cab; project "Eleanor" - Page 5 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 5th, 2014, 08:58 AM   #81
adamrz
Zombie Hunter
adamrz's Avatar
Default spring is here
And the fun time begins. We began tearing the front clip off of the donor 1996 powerstroke truck. And yes we took pictures.
Most of the front clip was bad enough (rust) that it was simply easier to cut off and pry off than it was it remove "properly".
Hoping to get to the drivetrain tonight, or tomorrow at the latest.
Pictures to come.
adamrz is offline   Reply With Quote
Old May 5th, 2014, 10:49 AM   #82
adamrz
Zombie Hunter
adamrz's Avatar
Prior to tear down:
Old May 5th, 2014, 10:53 AM   #83
adamrz
Zombie Hunter
adamrz's Avatar
hoping to get the "heart" out by tomorrow.
Old May 5th, 2014, 10:54 AM   #84
Trail Junkie
iamfawkinwithyou
Trail Junkie's Avatar
How bad is the core support in the donner?...i need one
Old May 5th, 2014, 11:40 AM   #85
adamrz
Zombie Hunter
adamrz's Avatar
It is toast in my opinion. you can come check it out if you want today, we will be out there around 5 draining pertinent fluids and working on a cj7.
Old May 5th, 2014, 02:28 PM   #86
kmanxj5011
kmanxj5011's Avatar
Are you going to be selling any parts off the donor?
kmanxj5011 is offline   Reply With Quote
Old May 6th, 2014, 06:52 AM   #87
adamrz
Zombie Hunter
adamrz's Avatar
PM me. If its drivetrain related, no.
Old May 6th, 2014, 07:22 AM   #88
adamrz
Zombie Hunter
adamrz's Avatar
Default parts and bits extracted
Things I knew but didn't really contemplate;
A cummins swap would have been way easier. Lol. Oh well, mine will be unique then.
Gas pedal? check!
Snagged the computer, controllers, modules, harness, anything and everything cause you just never know.
Brake upgrade, sure, I will take all that as well...
There will be some fab work in the near future I fear;
Old May 6th, 2014, 07:27 AM   #89
frdboy
frdboy's Avatar
I would look into running a hydro-boost sys off a 99+ SD and get rid of the vac. pump and vac. booster.
Old May 6th, 2014, 07:36 AM   #90
adamrz
Zombie Hunter
adamrz's Avatar
So this pirated brake set up from the donor is not as good? Is the set up you are talking backwards compatible with this 1996 7.3?
I am down for all suggestions, as this is a black of hole of hands on learning at its finest.
Old May 6th, 2014, 09:43 PM   #91
adamrz
Zombie Hunter
adamrz's Avatar
So it took a little persuasion from the following friends of mine to get the radiator core support out of the way. I would like to thank Willard, Mr. Saws all, Mr air hammer, and Mr Angle grinder.
This truck had a rough life as evidenced by the amount of brunt force trauma inflicted to get this out of the way.
Old May 6th, 2014, 09:47 PM   #92
adamrz
Zombie Hunter
adamrz's Avatar
The end result is we are almost there. Disconnect connection to the starter, drive shafts, and grab the steering column and if the weathers cooperative, maybe out tomorrow. Either way, small victory today, and with it being tulip time, we of course had to have elephant ears!
Old May 7th, 2014, 08:48 AM   #93
sandguy356
bronco built for fun
sandguy356's Avatar
mmmmm, elephant ears!
how is the donor interior?
sandguy356 is offline   Reply With Quote
Old May 7th, 2014, 11:00 AM   #94
adamrz
Zombie Hunter
adamrz's Avatar
Donor interior is decent. I snap some photos and post as I am hoping to pull steering column tonight.
Old May 7th, 2014, 11:02 AM   #95
adamrz
Zombie Hunter
adamrz's Avatar
Default diesel question
The donor is a 1996. From what I am reading, I do not need the steering column (chip/key/computer) for this year, its a standard column overall whereas the newer models have the chipped key, or necessary stuff in the column that are necessary to start the truck.
Can some one here educate me on this?
Old May 12th, 2014, 07:01 PM   #96
adamrz
Zombie Hunter
adamrz's Avatar
So the motor is free. Blood, sweat, beer, and curse words. Couldn't have done it without everyone's help.
Old May 12th, 2014, 07:03 PM   #97
adamrz
Zombie Hunter
adamrz's Avatar
More fun...
Old May 12th, 2014, 07:07 PM   #98
adamrz
Zombie Hunter
adamrz's Avatar
I grabbed the entire wire harness and steering column. Still not 100% I need it...
Old May 21st, 2014, 09:22 PM   #99
adamrz
Zombie Hunter
adamrz's Avatar
So I got everything inside my garage...barely. Had to let the air out of the tires to make it fit, but its there. June 5th pulling back out and headed to sturgis, mi for the mock fit and custom mount fabrication. Beyond excited!!!
Old May 21st, 2014, 09:24 PM   #100
adamrz
Zombie Hunter
adamrz's Avatar
Thinking of keeping the stickers, as an homage to the guy I rescued this from.
Thoughts?
Page generated in 0.66486 seconds with 84 queries
