*FOUND/SOLD* Trade my F350 11-leaf (12 w/overload) springs for lighter-duty springs - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 11th, 2013, 07:44 PM   #1
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
Default *FOUND/SOLD* Trade my F350 11-leaf (12 w/overload) springs for lighter-duty springs
I have a set of 11-leaf plus overload spring (12 total) from a low-mileage '99 F350 Superduty Cab & Chassis frame that I'd like to trade for your lighter-duty (6-leaf) springs. These should be a direct fit for '99-up F250, F350 & F450 (possibly more), from my understanding.
Who needs to add some beef to the back of your F-series truck?
Located in Cedar Springs (49319), but pick-up right in Grand Rapids near US-131/I-196/I-96 is also an option.
Thanks,
Craig
1x1_Speed_Craig is offline
Old December 11th, 2013, 11:15 PM   #2
Shotgun
I only wheel with boats.
Shotgun's Avatar
TONKA toy?
Shotgun is offline
Old December 12th, 2013, 04:06 PM   #3
I wonder how stiff my f250 would ride with those, or how much it would end up lifting it.
CheapThrillB2 is offline
Old December 12th, 2013, 05:36 PM   #4
1x1_Speed_Craig
Simplify...
That, I do not know, as I have never had any vehicle bigger/heavier than my Jeep LJ. However, I do know they'll be way too stiff for my relatively light project (Jeep F170 cab/flatbed mounted on an F350 Cab & Chassis frame. :)
Old December 12th, 2013, 05:38 PM   #5
1x1_Speed_Craig
Simplify...
Default Trade my F350 Superduty 11-leaf (12 w/overload) springs for your lighter-duty...
Regarding the height, I can grab a measurement for you this weekend, if it's something that would help.
Old December 12th, 2013, 06:05 PM   #6
Shayne_354
Shayne_354's Avatar
I wish I could hang those on my dodge n u fit mine. Glwt
Shayne_354 is offline
Old December 12th, 2013, 06:10 PM   #7
If you could measure how thick the pack is at the u bolts and from spring eye to eye. That would be great.
Old December 13th, 2013, 05:25 AM   #8
1x1_Speed_Craig
Simplify...
6 1/8" tall without overload spacer/spring, and 7 5/8" tall with overload spacer/spring (both measurements include the bottom 2 1/4" shim block, which I assume your has, as well).
Main eye-to-main eye is 54 1/4".
Old December 18th, 2013, 07:56 AM   #9
1x1_Speed_Craig
Simplify...
I'm 95% certain I'm buying a used set of springs from another member here. Once they're in-hand (or potentially before), I'll sell my HD springs outright, and am open to offers.
Thanks,
Craig
Old December 18th, 2013, 08:11 AM   #10
kickstand
circling the drain
kickstand's Avatar
I "Think" these are the springs that were on my F350, 4 door long bed. 305 or 315's can't remember. I think 305's. It rode fine with the long wheelbase. was about 2" taller than hancho's F250. My truck also had add a leaves up front to level it off. If those springs were NOT an option on my truck, then I had some aftermarket leaves added and or aftermarket springs, but i recall 10-12 leaves when I counted one time, and the factory block.
kickstand is offline
Old December 18th, 2013, 01:13 PM   #11
Shoot me your price. I don't wanna tear mine apart and give you mine then find out these won't work and be forced to buy new springs in the end.
Old December 19th, 2013, 07:09 AM   #12
1x1_Speed_Craig
Simplify...
PMd you, CheapThrillB2.
Old December 19th, 2013, 07:38 AM   #13
And returned
Old December 19th, 2013, 05:06 PM   #14
1x1_Speed_Craig
Simplify...
And returned
SOLD to CheapThrillB2. Thanks John. I'll connect with you this weekend after I get them removed.
Craig
Old December 27th, 2013, 11:27 AM   #15
Just to give you a heads up. Their was some slight difference between my old springs and these springs. I had to modify my ubolt plate for these to work.
My springs had the leaf pack/overloadspacer/overload spring all held together with the spring pack bolt. This meant the top of the overload had the nut. The pack I got from you they were all seperated leaving a peg sticking up through the over load. My bolt plate didn't fit. The hole on the plate was way to large and sat up higher off the spring. I had to weld a spacer into the plate to make up the difference.
If you get springs like my 03 had and you plan to reuse your old ubolt plate, you will most likely have to drill out the plate in the center to open it up. Just wanted to give you a heads up.
My truck seems to sit level now and rides like a lumber wagon , thanks again 1x1speed .
Page generated in 0.52732 seconds with 68 queries
