porter cable dry wall sander - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 9th, 2013, 11:39 AM   #1
mideerslayer
NEVER GIVE UP!
mideerslayer's Avatar
Default porter cable dry wall sander
I have a hardly used Porter cable 7800 drywall sander with hose just need to hook it up to a shop vac
Plus it comes with a box of sanding pads
Here are the specs I also have 4 extra 120 grit sanding pads
$350 obo
Only trade would be for a dlsr camera set up
Porter Cable 7800 Specifications:• Power: 120 VAC, 60 HZ • Motor Amps: 3.4 Amp AC Only • Speed: Variable 1,400-2,000 RPM • Pad Size: 8-7/8 • Pad Type: Foam-Backed • Pad Mount: Compression Type • Length: 62 Porter Cable 7800 Includes:• Sander• Sanding pad• 13' static-dissipating 1-1/4 vacuum hose• Hook & loop straps for mounting power cord to vacuum hose• Operating manual• Vacuum not includedPorter Cable 7800 Features:• Variable-speed dial (1,400 - 2,000 RPM) • Built-in dust collection hose • 1-1/4 vacuum hose is 13' long so that large areas can be sanded in one set up
mideerslayer is offline   Reply With Quote
Old December 21st, 2013, 09:22 AM   #2
mideerslayer
NEVER GIVE UP!
$250 or I will just ebay it after Christmas, there going for $300+ and shipping on top of that
Page generated in 0.17101 seconds with 29 queries
