GL4x4 Live! GL4x4 Casino GL4x4 Arcade
Thread Tools Display Modes
Old November 10th, 2006, 08:22 AM   #1
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
Jeep CJ-10a conversion project (now w/video)
As many of you know, I am getting one of my CJ-10a Flightline Tugs ready for plowing this Winter (with the help of FORD FLARESIDE). I have a 2nd tug that I'm converting for road/offroad use. I'm excited about this project, as it doesn't require a complete ground-up build. Time is a commodity for me right now, and this tug ran/drove well (up to ~18 mph) prior to me pulling the rear axle and bobtail bed. My plans for this tug are relatively straightforward, and include the following:
  • Keep it on the cheap by bartering for parts where I can.
  • Retain stock Nissan SD-33 6-cyl. diesel motor and TF-727 auto transmission.
  • '90 GW Dana 44 front axle: I'm in the process of cleaning this axle up for paint; see photo below. It'll need a 4.10 re-gear, and I'd like to convert it to manual lockouts and add a locker. I'll see how the budget goes. This axle is a bolt-in for the '10a (translation = easy swap).
  • Isuzu Rodeo Dana 44 rear axle: Cooter scored me one of these, and I'm getting it in trade for some Scrambler parts. It has 4.10 gears, rear disc brakes, 6 x 5.5" lug pattern, and it's ~58" wide WMS-to-WMS. It'll be a great match for the NT FSJ front axle.
  • Plain-Jane Toyota 4-Runner steel wheels: Free from Mr. Stabby (I owe you one, Joe). These have a 6 x 5.5" bolt pattern, and I love the ultra-basic style of this wheel (it retains basically the same look as the stock 8-lug military wheels that came on the '10a). I'll just blast 'em and paint 'em black.
  • NP-208 T-case: I swapped an NP-229 case for this one (thanks 46flattie). It'll replace the AMC 198 case that's currently in the tug, and locked in low-range. The 208 is a bolt-in affair, and I'll just need to extend the shift linkage by ~4"...an easy fix.
  • 32" x 9.5" Swampers: I also got these from Cooter on trade. The size will allow me to retain a stock height, and not have to buy a lift kit. NOTE: Even with a lift, the front tire size using the stock CJ-10 front fenders is limited due to the wrap-around in front.
  • Reworked rear springs to extend wheelbase (see more info below).
  • Flatbed rear w/a cage of some sort. I hope to talk with the JCR guys about this, maybe sometime next Spring.
  • Pintle hitches front & rear.
I'm trying to assess how I'm going to address moving the rear axle back. The existing rear spring setup (check out those monster rear leafs) are all FSJ, outboarded w/56-57" spring packs (HD of course, for this application). The stock setup is SOA, with an off-center pin. Reversing the spring will move the axle back about 5 1/2" over stock, but that's not far enough for what I want. Instead, I think I'll use a 2nd set of front FSJ springs, and relocate them under the frame rails. This would require an SUA setup to maintain the existing ride height. By going under the frame rail and using the front Waggy springs (2" pin offset), I'll be able to move the rear axle back roughly to where the tire is positioned in the photo below. I considered switching to 63" Chevy springs, but they'd be too long for this frame setup.
Anyway, I'll be working on this project over the Winter. The only attention the tub will require is the repair of a tiny (smaller than a dime) hole in the passenger floorpan. Other than that, it's all rust-free.
So there it is. This project will require substantially less work than a full frame-up build, but will still be a unique and rust-free Jeep that should probably get 28 mpg with the 6-cyl. Nissan diesel motor it has.
Craig
ID:	4125   Click image for larger version
ID:	4127   Click image for larger version
ID:	4129   Click image for larger version
ID:	4130   Click image for larger version
Old November 10th, 2006, 09:05 AM   #2
Jeepaholic
Douche Mod #1
Jeepaholic's Avatar
So is it and still gonna be SUA in the front, I can't remember if it was or not? Sweet project, sort of gonna look like a land crusier when it is done. Keep us updated!
Axle Guru Extraordinaire
Old November 10th, 2006, 11:45 AM   #3
mrclean
Swamp Stomper
mrclean's Avatar
Nice I like it.
Are you going to leave the slab weight in the rear for added traction wheeling? :tonka:
Keep us updated
mrclean is online now   Reply With Quote
Old November 10th, 2006, 12:36 PM   #4
Monkeyevil
Now abduction FREE!
Monkeyevil's Avatar
How about keeping the springs out boarded and making a new bumper that has rear shackles mounts in the back? Like the YJ guys do to run XJ leafs.
You could make a bumper with the same style, but mount it a little cleaner and stuff.
JcrOffroad
Renegades FTW.
Old November 10th, 2006, 01:52 PM   #5
1x1_Speed_Craig
Simplify...
Originally Posted by 99grandtj View Post
So is it and still gonna be SUA in the front?
Yes, it's going to be SUA (same as OEM FSJ).
Uh, no. It should give me some good salvage $$$ to put toward other parts, though. That slab o' weight is 4" thick, and ~2000 lbs.
That thought crossed my mind (using Chevy rear springs). I think it'll help rear flex by moving them underneath, though. You're more the expert than I am, though.
Craig
Old November 10th, 2006, 05:19 PM   #6
drummond
MTU 4x4
drummond's Avatar
looks very nice as always craig. nice progess
drummond is offline   Reply With Quote
Old November 11th, 2006, 09:40 PM   #7
PotatoC
PotatoC's Avatar
Send a message via AIM to PotatoC
Always awesome to see someone doing a project that is different then all others!! Looks great man!!
PotatoC is offline   Reply With Quote
Old November 15th, 2006, 06:44 AM   #8
1x1_Speed_Craig
Simplify...
Thanks guys.
I just ordered a set of these Sky Manufacturing spring hangers, and some JC Whitney 5-leaf Waggy springs (PN# ZX072047B) to mount on the rear of the tug.
I got the track bar bracket removed from the front Dana 44 axle, and I'm still working on wire-wheeling it (lots of nooks & crannies on a front D44). I'm also working on wire-wheeling the NP-208 t-case, and have it about 50% done...bling, bling. :tonka:
More pics to come...
Craig
Old November 25th, 2006, 05:58 PM   #9
1x1_Speed_Craig
Simplify...
The spring hangers & leaf springs are now here. The wheels are currently at the sandblaster, and they'll be painted with POR-15/self-etching primer/Krylon when they're done. I also shipped the front Dana 44 off to Five Star Auto for them to give it a basic overhaul & regear (used Rubi 4.10s), and just picked up the Isuzu Dana 44 today from Cooter.
The pieces are coming together, and I actually feel like I'm making progress on this project.
Craig
Old December 6th, 2006, 09:54 AM   #10
LuckyCharm4x4
LuckyCharm4x4's Avatar
Send a message via AIM to LuckyCharm4x4 Send a message via Skype™ to LuckyCharm4x4
what's the status?
~Bry
LuckyCharm4x4 is offline   Reply With Quote
Old December 6th, 2006, 03:42 PM   #11
1x1_Speed_Craig
Simplify...
Originally Posted by LuckyCharm4x4 View Post
what's the status?
~Bry
It's only been a few days since you've seen it, "Mr. Microwave Society". :miff: I prefer the "crock pot" approach to my projects (translation = wife, kids, work, etc. delay rapid progress on my projects). :tonka:
But, I digress...
The wheels are now painted, and I'll be getting the 32" TSLs mounted on them shortly. The front Dana 44 is with my friends at Five Star Auto, getting rebuilt with 4.10s, Detroit Truetrac, new bearings/seals/ball joints, etc. I'll probably start removing the spring perches on the Isuzu rear axle this weekend, and will subsequently wire-wheel & paint it.
The best parts of the project right now, though, are the wonderful jack stands that are holding the back end off the ground.
Craig
I'm actually spending most of my time trying to get my other CJ-10a ready for plowing. I'm still a solid 2-3 weeks away from that being done.
Old December 6th, 2006, 08:06 PM   #12
MyAdidas
MyAdidas's Avatar
I agree on it being exciting to see someone doing something different like this.
(You should link your signature to these buildups.)
MyAdidas is offline   Reply With Quote
Old December 15th, 2006, 08:17 AM   #13
PavementPounder
PavementPounder's Avatar
Send a message via Skype™ to PavementPounder
[*]Isuzu Rodeo Dana 44 rear axle: Cooter scored me one of these, and I'm getting it in trade for some Scrambler parts. It has 4.10 gears, rear disc brakes, 6 x 5.5" lug pattern, and it's ~58" wide WMS-to-WMS. It'll be a great match for the NT FSJ front axle.
Is this an aluminum axle housing?
This is how NAXJA Midwest Chapter elected officials like to treat their resident users and former multi-year supporters.
Their leadership is headed in the wrong direction. Do not support them.
Old December 16th, 2006, 08:24 AM   #14
Cooter
Dad Kickin' It OldSkool
Cooter's Avatar
Nope- pretty much a regular Ol' D44 with 6 lugs, discs, and a ABS tone ring.
Old December 17th, 2006, 04:15 PM   #15
1x1_Speed_Craig
Simplify...
Ditto. I'll post pics in a couple weeks once I get the rear axle hung under the Jeep.
Craig
Old December 25th, 2006, 05:13 PM   #16
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
Any new updates Craig? You got me looking at a CJ10A now.
Old December 25th, 2006, 06:11 PM   #17
1x1_Speed_Craig
Simplify...
I hope to post pics later this week. I got the rear bumper, the stock rear shackle hangers, and the almost 2K-lb. weight removed from the back of the vehicle. It was no easy task with the weight, BTW...it was welded to the frame in 6 different places, and took a combination of carefull die grinding & saw-zalling (is that a word?) to remove it. I did realize that I'll have to outboard the rear shackle hangers slightly, as the frame narrows a little in back...I couldn't see this with that big friggin' weight in the way.
I'll have a decent amount of time to work on it this week...stay tuned for more pics.
Craig
Old December 25th, 2006, 09:30 PM   #18
4x4forlife
4x4forlife's Avatar
looking good, I always like to see weird jeeps,
4x4forlife is offline   Reply With Quote
Old December 26th, 2006, 09:44 PM   #19
1x1_Speed_Craig
Simplify...
I got the rear spring hangers aligned and tack-welded on tonight. It looks like I'll have to outboard the rear shackle hangers 1", as the rear portion of the frame is narrower than where the front spring mounts are located.
Tomorrow night...finish removing the other spring perch from the Isuzu D44 rear axle, and get it hung underneath the tug.
Exxxxx-cellent.
Craig
ID:	5413   Click image for larger version
Old December 27th, 2006, 07:59 PM   #20
suepahfly
professional webwheeler
suepahfly's Avatar
Looks good.
suepahfly is offline   Reply With Quote
Thread Tools
Display Modes
Powered by: vBulletin Version 3.8.4, Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright ©2005 - 2009 Cracker Enterprises - Powered by Linux
Forums Directory
Page generated in 0.44026 seconds with 54 queries
