Mythbusters, I need your help. Does a 4wd vehicle stop better in the snow? - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
View Poll Results: Does a 4wd vehicle stop better in the snow?
Yes. 8 11.94%
No. 49 73.13%
Kick Cube in the junk. 10 14.93%
Voters: 67. You may not vote on this poll
Old December 9th, 2013, 05:45 AM   #21
curbdog17
Mini Van
curbdog17's Avatar
I like turtles
Old December 9th, 2013, 05:55 AM   #22
Blue XJ
The Green Machine
Blue XJ's Avatar
Send a message via AIM to Blue XJ
Assuming your vehicle isn't a piece of shit and all the brakes work as intended, it will not make a difference. Front tires shouldn't be locking up causing the rears to lock up, time for a less shitty car if thats what is happening.
Blue XJ is offline   Reply With Quote
Old December 9th, 2013, 06:13 AM   #23
bigbchevy
missmrgreenagain
bigbchevy's Avatar
Originally Posted by curbdog17 View Post
I like turtles
H.o.r.e
Old December 9th, 2013, 06:33 AM   #24
Only advantage I've ever seen is better traction in some conditions. But it has nothing to do with 4wd, just the tires that are typically on a 4wd vehicle.
Old December 9th, 2013, 06:35 AM   #25
bigbchevy
missmrgreenagain
bigbchevy's Avatar
where the hell is hancho at on this one!!!!!!!!
H.o.r.e
Old December 9th, 2013, 06:39 AM   #26
Mr.Green
I can levitate!
Mr.Green's Avatar
Originally Posted by JimNut View Post
In a perfect world where each of the 4 tires are able to apply the maximum amount of braking before locking up and losing traction on an individual bases, 4wd or 2wd would not make any difference in stopping ability.
Its ok Hancho, I got this one: This ^^^^^ is pretty much the right answer. Yes there are many circumstances where people have bad braking systems or horrible tires where 4x4 could be an advantage. But the basic answer is no, 4x4 does not stop better when comparing the same vehicle, with the same tires and the same CG height and everything functions as it is supposed to.
Old December 9th, 2013, 07:42 AM   #27
JimNut
JimNut's Avatar
Originally Posted by go1lum View Post
How would this work with a 231 case if you had one. In 4 wheel the drive shafts are locked at the same speed. If front end is locked up the back has to be too also right. Vs. Being in 2wd ?
No difference . The driveshafts may be locked at the same speed but the front axle is not engaged unless in 4wd.
JimNut is offline   Reply With Quote
Old December 9th, 2013, 08:02 AM   #28
kickstand
circling the drain
kickstand's Avatar
Originally Posted by MonkeyBiz View Post
HUH
It's not that confusing.
When engaged in 4wd the transfer case connects the front and rear driveshafts. His rear tires are now slowed by his driveshaft. Before the rear brakes were not helping to slow.
Old December 9th, 2013, 08:03 AM   #29
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
No, it doesn't assuming all other variables (tires, weight, brakes, etc.) are the same.
Old December 9th, 2013, 08:20 AM   #30
BlooMule
Old School
BlooMule's Avatar
If only there was a way to engage 4WD without disengaging the brain for many drivers...
-rw-rw-rw
BlooMule is online now   Reply With Quote
Old December 9th, 2013, 08:23 AM   #31
SS
Bananarama!
SS's Avatar
Momma taught me as a kid that four wheel drive may get you going in the snow but it sure as hell don't help ya stop.
Two spin outs in my first car (94 Wrangler) taught me Momma was right.
-Jer
Old December 9th, 2013, 08:40 AM   #32
Ebs
It probably can help if you don't have modern 4-wheel ABS, only because you lessen the chance for individual wheels to lock and lose traction.
Old December 9th, 2013, 08:46 AM   #33
Immortal
NO RELIGION WAT!
Immortal's Avatar
Always accelerate in a situation needing to avoid a collision. Especially in 4wd.
What happens is the tires will spin at a high rpm causing friction allowing the tire to sink through the snow and ice. Once the tire makes contact with the pavement you will have complete control because of traction to avoid a collision.
This does not work with fwd or rwd vehicles.
Old December 9th, 2013, 08:51 AM   #34
bigbchevy
missmrgreenagain
bigbchevy's Avatar
lol
H.o.r.e
Old December 9th, 2013, 09:13 AM   #35
GreaseMonkey
Pew pew!
This is exactly why you never take driving advice from an Asian.
Old December 9th, 2013, 09:15 AM   #36
bigbchevy
missmrgreenagain
bigbchevy's Avatar
H.o.r.e
Old December 9th, 2013, 11:02 AM   #37
Padilen
Padilen's Avatar
THIS.
Except now I'm telling her it.
Hoping she remembers it.
Padilen is offline   Reply With Quote
Old December 9th, 2013, 11:20 AM   #38
brewmenn
Mr. Special Snowflake.
brewmenn's Avatar
It depends on the vehicle and the conditions. With ABS it probably doesn't make a difference. Without ABS it could help prevent one wheel or axle front locking up before the other, maybe helping stop. But it could also help lead to all 4 tires locking up and causing the vehicle to spin out of control.
Old December 9th, 2013, 11:48 AM   #39
mschaffer66
mschaffer66's Avatar
Momma also said Vicki Vallencourt was the devil.
Old December 9th, 2013, 12:33 PM   #40
SS
Bananarama!
SS's Avatar
Too bad Momma. She showed me her boobies and I liked them.
-Jer
Page generated in 0.30719 seconds with 83 queries
