Mythbusters, I need your help. Does a 4wd vehicle stop better in the snow? - Great Lakes 4x4. The largest offroad forum in the Midwest
View Poll Results: Does a 4wd vehicle stop better in the snow?
Yes. 8 11.94%
No. 49 73.13%
Kick Cube in the junk. 10 14.93%
Voters: 67. You may not vote on this poll
Old December 8th, 2013, 08:44 PM   #1
gofastbobby
The guy Dale doesn't know
gofastbobby's Avatar
Default Mythbusters, I need your help. Does a 4wd vehicle stop better in the snow?
I am curious to know.
Originally Posted by FlatFender View Post
America! Fuck yeah!
gofastbobby is offline   Reply With Quote
Old December 8th, 2013, 08:46 PM   #2
87mopar
Web Wheeler :(
87mopar's Avatar
No, if anything it would make you slide easier depending on the vehicle.
"Insert Comedic and or ego boosting quote questioning another members sexual orientation here"
http://www.greatlakes4x4.com/imageho...60bd7ea6d9.gif
87mopar is offline   Reply With Quote
Old December 8th, 2013, 08:48 PM   #3
Badmunky
Badmunky's Avatar
No auto stops better in snow!
Kick to the junk!
Badmunky is offline   Reply With Quote
Old December 8th, 2013, 08:48 PM   #4
PinItToWinIt
PinItToWinIt's Avatar
Nope no way..
PinItToWinIt is offline   Reply With Quote
Old December 8th, 2013, 08:59 PM   #5
firehawk
Live Action!
firehawk's Avatar
Probably takes more due to the extra weight of the 4x4 parts.
Old December 8th, 2013, 09:06 PM   #6
14muddn
Stop? When in doubt throttle out!
Old December 8th, 2013, 09:09 PM   #7
JimNut
JimNut's Avatar
I have noticed that my jeep does stop much better in the snow when I have the 4wd engaged. Only reason though is my rear drum brakes are pretty shitty so at least when the 4wd is engaged the front brakes help out with stopping the rear.
JimNut is offline   Reply With Quote
Old December 8th, 2013, 09:13 PM   #8
jeepinRRT
jeepinRRT's Avatar
The front brakes stop all vehicles, the back is just along for moral support, regardless of 2x4 or 4x4.
jeepinRRT is offline   Reply With Quote
Old December 8th, 2013, 09:14 PM   #9
MonkeyBiz
Master Cocksman
MonkeyBiz's Avatar
HUH
Old December 8th, 2013, 09:17 PM   #10
Padilen
Padilen's Avatar
This is a myth?;).
Nope, I think a little harder in snow and on ice
Higher off the ground, weight shifts. But they keep messing with 4 wheel drive vehicles making them lower.
Padilen is offline   Reply With Quote
Old December 8th, 2013, 09:28 PM   #11
booblinker
Sore and Tired 24/7
booblinker's Avatar
more traction, more weight, and usually same size brakes, yup should stop better.
booblinker is online now   Reply With Quote
Old December 8th, 2013, 09:38 PM   #12
JimNut
JimNut's Avatar
Originally Posted by MonkeyBiz View Post
HUH
When 4wd is engaged you cant lock up the brakes on only one axle. There for if you have really shitty brakes on one of your axles the vehicle will stop better in 4wd because the braking power from the good axle is also transferred to the shitty axle. Make sense?
Old December 8th, 2013, 09:52 PM   #13
littletrucker
I'd hit that
littletrucker's Avatar
Would a 4wd or a 2wd cherokee stop any different? No.. It comes down to the tires. A 4wd would just get your moving faster and probably into more trouble.
Old December 8th, 2013, 09:55 PM   #14
MonkeyBiz
Master Cocksman
MonkeyBiz's Avatar
Essentially, since you can't do a brake stand in 4wd, the same must be true for stopping... Is that what you're saying?
Old December 8th, 2013, 10:40 PM   #15
JimNut
JimNut's Avatar
Pretty much. My jeep has 38.5 x 15 super swamper TSL's that are absolutely terrible on slick roads. For me it is not uncommon at all to lock up the front tires long before the rears. When in 4wd this issue no longer exists and stops much better on slippery conditions. Atleast for my jeep anyways.
In a perfect world where each of the 4 tires are able to apply the maximum amount of braking before locking up and losing traction on an individual bases, 4wd or 2wd would not make any difference in stopping ability.
Old December 8th, 2013, 10:51 PM   #16
go1lum
How would this work with a 231 case if you had one. In 4 wheel the drive shafts are locked at the same speed. If front end is locked up the back has to be too also right. Vs. Being in 2wd ?
go1lum is offline   Reply With Quote
Old December 8th, 2013, 11:44 PM   #17
Jiveturkey3
Jiveturkey3's Avatar
I'm not sure what in the hell you are saying. However, brakes are cheap, why do you have shitty brakes?
Jiveturkey3 is offline   Reply With Quote
Old December 8th, 2013, 11:58 PM   #18
fordf250man
fordf250man
fordf250man's Avatar
it can help slow you down but not stop, ice and snow doesn't care how many wheel drive you have, as you slow though if you have all four wheels engaged instead of two without slipping then you have two more wheels for traction thus helping the vehicle to slow down, when only two wheels are engaged then the other two are just rolling away
fordf250man is offline   Reply With Quote
Old December 9th, 2013, 12:05 AM   #19
firehawk
Live Action!
firehawk's Avatar
But I have anti lock brakes!
Old December 9th, 2013, 12:09 AM   #20
fordf250man
fordf250man
is it 4 wheel anti lock brakes? and Im not talking about braking, just slowing down when you let off the throttle
Page generated in 0.57920 seconds with 83 queries
