C5 Trans ******found**** - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 7th, 2013, 08:58 AM   #1
frdboy
frdboy's Avatar
Default C5 Trans ******found****
Looking for a rebuildable C5 trans, can be 2wd
The way to pick a c5 from the outside is the fine threaded front band adjuster, the large 1/4" thread on the cooler fittings and the E2 casting code.
frdboy is offline
Old December 7th, 2013, 10:38 PM   #2
AtvNut
AtvNut's Avatar
Send a message via Yahoo to AtvNut
what T case are you going to use?
Thanks
Jeff
call or Txt
313-510-2083
AtvNut is offline
Old December 7th, 2013, 11:20 PM   #3
frdboy
frdboy's Avatar
Dana 20
frdboy is offline
Old December 13th, 2013, 06:29 AM   #4
frdboy
frdboy's Avatar
up
frdboy is offline
Old January 8th, 2014, 05:54 AM   #5
frdboy
frdboy's Avatar
Still looking
frdboy is offline
Old January 8th, 2014, 07:14 AM   #6
AtvNut
AtvNut's Avatar
Is there any reason you want to run a c5 over a c4?
http://www.fordmuscleforums.com/all-...rovements.html
Thanks
Jeff
call or Txt
313-510-2083
AtvNut is offline
Old January 8th, 2014, 07:18 AM   #7
frdboy
frdboy's Avatar
I like the c5 cases better......they have better (bigger) cooling circuit and a few other upgrades over the the C4 case......but I will run a C4 if I don't find one easy and soon.
frdboy is offline
Old January 8th, 2014, 09:37 AM   #8
Daddy Dan
SBF Nut
Daddy Dan's Avatar
I have one. Its from an '84 Bronco II. I sold off the 2.8l bell housing and the 4x4 tail and output shaft. I kept it to build a C4/C5 combo. I have the C5 and a C4 in parts(both 2wd). PM if your interested.
Daddy Dan is offline
Old January 9th, 2014, 08:18 PM   #9
frdboy
frdboy's Avatar
Up
frdboy is offline
Old January 16th, 2014, 03:46 PM   #10
frdboy
frdboy's Avatar
Up
frdboy is offline
Old March 28th, 2014, 08:11 PM   #11
frdboy
frdboy's Avatar
Up
frdboy is offline
Page generated in 0.24659 seconds with 56 queries
