Jeep FC170 "Patina Rod" - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 19th, 2014, 06:31 AM   #41
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
Originally Posted by jbsjunk View Post
Hopefully the radius arms are there and the bolts for them.
Yes, I'm getting the whole front half of the frame (still assembled).
Originally Posted by stevelknievel View Post
Love this thing already looks like it's going to be killer man
Originally Posted by roll-bar Bob View Post
keep the photos coming
Thanks guys. It'll be a slow build, but it's coming together. I'm shooting for 1 1/2 - 2 years to build it.
Old January 21st, 2014, 05:52 PM   #42
nixxerRsixxer
Homewrecker
nixxerRsixxer's Avatar
For sale yet?
nixxerRsixxer is offline   Reply With Quote
Old January 21st, 2014, 06:20 PM   #43
1x1_Speed_Craig
Simplify...
Originally Posted by nixxerRsixxer View Post
For sale yet?
No
Old January 24th, 2014, 07:08 PM   #44
1x1_Speed_Craig
Simplify...
More parts falling into place...
My girls helped me tear down a '92 Cherokee last weekend (in & out in 24 hours). In the course of doing so, we got some almost-new brake pads & rotors for 13-year-old Mira's '97 XJ 2-door, and an engine to use for mock-up in my FC project (actually, I'm trading this good-running engine for a bad engine plus a little cash). The girls earned some extra $$$ for their hard work, and we all celebrated the completion of the tear-down by going to see the movie "Frozen", which was a lot of fun.
The Cherokee also kindly donated a "mock-up" NP-231 (it's actually a functioning t-case), as well. I have a loaner AW4 auto coming soon, too.
Underneath this snow lies my new-to-me 2005 F350 Dana 60 and complete front suspension (and rear leaf springs, not shown), which I'm picking up tomorrow morning. These bolt-on parts will get me into a (semi-)rolling status in no time.
Old January 24th, 2014, 07:48 PM   #45
jbsjunk
Little Member
jbsjunk's Avatar
Looks like you have all the hard parts now. Now you get dirty.
Old January 24th, 2014, 09:10 PM   #46
Easy_E
Web Wheeler !
Easy_E's Avatar
From Facebook
Easy_E is offline   Reply With Quote
Old January 24th, 2014, 11:13 PM   #47
cerial
Direct Drive FTW
cerial's Avatar
Sweet build.
It will be interesting to see how you fit the cab around the coils.
Old January 26th, 2014, 09:34 AM   #48
1x1_Speed_Craig
Simplify...
Originally Posted by cerial View Post
Sweet build.
Thanks cerial. Based on dimensions of the stock & F350 frames, I think it'll be very simple, actually. The F350 frame is ~10" wider up front than the stock frame. The inside vertical surface of the fenderwells on the cab align with the outside edge of the stock frame. I think the F350 coil buckets will just nest up into the fenderwells perfectly.
Old March 8th, 2014, 05:12 AM   #49
1x1_Speed_Craig
Simplify...
There hasn't been a lot of wrenching yet due to the sub-zero and/or single-digit temps and an incredibly busy schedule, but I do have a few updates.
I want to give a HUGE thanks to booster here on GreatLakes4x4 for giving me two (2) steelies with decent tires for FREE (it definitely helps me stick to my low budget!!!). I bought/rounded up the remaining wheels & tires, and some OEM front dually adapters from MARTIN HASSENGER here on GL. I'll stick with the steelies for my build, and may resell the two aluminum ones I ended up with, or keep them around as spares...who knows at this point. I got the rear springs and wheels/tires mounted up, and positioned under the rear of the vehicle. Last week, I also bought a set of of new U-bolts (AB Spring Service in GR) for the rear.
It looks like my friends at RockSolid Performance will be making me some front caliper adapters so I can fun smaller calipers/rotors, allowing me to use the 16" wheels on the front. They'll also do some very minor machining on the DRW spacers to fit over the 2005 hubs.
I also sold my Millermatic 135 welder, and bought a (230V) Millermatic 211. Given the thickness of the F350 C&C frame, the stronger welder will definitely be helpful! I have been eyeing the 211 for several years.
That's all for now. Hopefully, updates will occur more regularly now that spring is right around the corner. #PolarVortexFingWithMyProjectTimeline
Old March 23rd, 2014, 07:06 PM   #50
1x1_Speed_Craig
Simplify...
I opted to buy new springs seats (coil spring/shock towers) rather than cut the existing ones off the donor frame. I bolted up on the new frame with 7/16" bolts, but they're a little loose in the holes; the rivets I removed were a VERY tight fit, and required a good pounding with a small sledge & punch. I'll use these bolts for mock-up, but will replace them with either Grade 8 or Grade 9 (recommended by the dealership) before final assembly.
I also got the 2005 Dana 60 and all suspension parts removed from the donor frame today. With the weather breaking here in the "forever Winter" state (Michigan), I hope to get it bolted into the new frame in the next couple weeks.
Old March 26th, 2014, 05:56 AM   #51
John D
John D's Avatar
Not sure how missed this one, but it's pretty sweet. Good luck with it Craig, can't wait to see how it turns out.
Old March 26th, 2014, 06:28 AM   #52
1x1_Speed_Craig
Simplify...
Thanks John. I've enjoyed watching the ongoing progress on yours, too.
Old April 6th, 2014, 01:33 PM   #53
1x1_Speed_Craig
Simplify...
Well, the weather is finally breaking here (finally!), and I made some decent progress on my project this weekend. First and foremost, I now 220V power in the garage thanks to my friend Ron, so I'll be able to start using my new Millermatic 211 (I used a Millermatic 135 for years, and absolutely loved it).
I also wire-wheeled/sanded the '05 F350 radius arms, and got a coat of Eastwood primer on them. Once the finish coat is done, I'll use some Eastwood internal frame coating on them.
I started lightly sanding the coil springs to prep them for paint, but it took longer than expected, as the donor truck was undercoated, and they had a healthy coating just on the outside surface of the springs. I'll pick up on that work the next time I work on the truck.
Craig
Old April 6th, 2014, 08:47 PM   #54
Porscheguy
Porscheguy's Avatar
Nice welder, I bought the same one last year. Your going to like having 220 in the garage ;) Given the size of your rig, your going to like the extra power. I doubt you will use the full duty cycle of the 211.... has a ton of juice for how small it is!
Porscheguy is offline   Reply With Quote
Old April 8th, 2014, 10:22 AM   #55
jeepbob
IF you need FC150 or 170 parts let me know. I have a real good 170 frame with axles. D44 frt and D53 rear 4.88 gears I also have body and engine parts, 1 fc150 and 2 fc170
jeepbob is offline   Reply With Quote
Old April 8th, 2014, 10:36 AM   #56
1x1_Speed_Craig
Simplify...
Hey jeepbob, I'll keep it in mind. While mine won't be using any of the original frame/drivetrain, I'm looking at a group of FC150s that I may be purchasing, as well.
You don't happen to have any solid cabs, do you?
Old April 8th, 2014, 10:39 AM   #57
TOPTRUK
Never Ending....
TOPTRUK's Avatar
Awesome build! This will make for one sweet tow rig! Great work Craig!
TOPTRUK is offline   Reply With Quote
Old April 8th, 2014, 10:47 AM   #58
1x1_Speed_Craig
Simplify...
Can't wait to try it out!
Thanks Curtis. Much appreciated.
Old April 13th, 2014, 02:48 PM   #59
1x1_Speed_Craig
Simplify...
Sanding/prepping the coil springs for a fresh coat of Eastwood Extreme Chassis Black Satin paint spurred me thinking about the added weight of the cab on the front end of the F350 frame. I haven't been horribly concerned, as people throw heavy plows on the front of these things all the time. However, I wanted a little piece of mind with having that much weight that forward on the frame.
It looks like I definitely lucked out with the purchase of this 2005 F350 front frame half (below). The donor vehicle was equipped with a 6.0L Powerstroke, which I found has a dry weight of 920 lbs. (or 966 lbs. with oil). By comparison, the Jeep 4.0L that will power this truck weighs around 515 lbs...a 400-lb.+ difference! While I'm not certain what the FC cab weighs, I'd guess that it's between 300-400 lbs. I don't know what "code" my coil springs are, but I'm willing to bet that they're at the stiffest end of the spectrum in regards to spring rate.
The OEM radius arms have now been top-coated, and are in indoor storage until which time the axle is painted, and ready for install under the cab & chassis frame.
I also ran the BOM on the front axle, and it came back as a Dana "Super 60". What does this mean? Confusion, in most circles. The axle tube has a 3.75" diameter (1/2" wall thickness), bigger ring & pinion, and in some axles, bigger u-joints. All 2005+ Dana 60s have 35-spline shafts, so strength in this truck will not be an issue. I'll just have to have RockSolid Performance regear it to 4.30 at some point to match the rear.
Old April 20th, 2014, 05:31 PM   #60
1x1_Speed_Craig
Simplify...
I made some minor progress on Saturday. All accessories have been removed from the 2005 F350 Dana 60, and it's now ready to be wire-wheeled, sanded & painted. More Eastwood Extreme Chassis Black paint is en route.
Page generated in 0.50634 seconds with 83 queries
