Jeep FC170 "Patina Rod" - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 1st, 2013, 08:46 PM   #1
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
Default Jeep FC170 "Patina Rod"
First, all y'all with comments about parting it out shall shut your respective pie holes (for now ).
This will be a fairly low-budget build utilizing late-model drivetrain parts (many I already have), with an attempt to maintain the character/patina of the FC cab. I posted
this thread in The Pub
, but now I'm committed...or perhaps I should be. Here's the plan (updated below as parts/plans have changed):
  • Repair the floors in the cab and neutralize exterior rust as much as possible. Prep/paint the interior nicely, but retain the existing exterior paint scheme/patina, rust, etc.
  • Mount the cab on a 2008 Ford F350 Cab and Chassis frame (see below) painted nicely in satin black.
  • Mid-engine install of a '95 Cummins 6BT, 47RH 4WD transmission and 2001 Dodge NP241 DHD Transfer Case.
  • Build custom bumpers.
  • Build a semi-custom bed. The original bed is shot, so repair is not an option. Some of you chimed in and suggested rebuilding a bed like the stock one, but for me, the flatbed will give me the utility I need, and be a lot easier/cheaper than trying to reconstruct the stock-style bed.
  • Tire size? Stock F350 (~31-32" tall).
  • Must be built with a meager budget.
The FC170 cab donor (see below). I originally started with a different "Dan's Snowplowing" FC170 cab, but plans changed when I found the (better-condition) gray/patina FC170.
Jeep Commander "Saddle Brown" leather seats blend beautifully with the patina, and will add a touch of class to the interior. Matching custom leather arm rests and sun visors will complement the seats.
I wanted a stout, longer-than-stock heavy-duty frame for my project. Rather than work with the original frame, I decide to mount the cab on a late-model F350 Cab & Chassis frame, allowing me to use off-the-shelf suspension & axle parts. Ultimately, I landed on using a 74K-mile 2008 frame, which included the fuel tank, lines, etc. It also has the side pieces for a hitch (but not the center section).
The Ford Body Builder Guide on the Ford Fleet site has been an incredible resource for dimensional data.
I got the narrow F350 Cab & Chassis Dana 80 (71.1" WMS-to-WMS) from the same 2008 F350 C&C. Gear ratio is 3.73.
The front axle is a Dana Super 60 (3.73 ratio) from a 105K-mile 2005 F350 pick-up. I replaced the ball joints, U-joints & pinion seal, and am just finishing up getting the axle & suspension parts cleaned up & painted.
1994 Cummins 12v 6BT, 230K miles
Rebuilt 1994-1995 Dodge 47RH 4WD automatic transmission & 2001 NP241 DHD transfer case
Old December 1st, 2013, 09:13 PM   #2
muddinman56
blood,sweat and beers
muddinman56's Avatar
That's bad ass
Old December 1st, 2013, 09:55 PM   #3
beejers
always building
beejers's Avatar
me like
beejers is offline   Reply With Quote
Old December 2nd, 2013, 04:09 PM   #4
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
Cool looking project.
RIP FULLSIZE4LIFE
Old December 2nd, 2013, 05:52 PM   #5
jbsjunk
Little Member
jbsjunk's Avatar
In for ideas.
Old December 2nd, 2013, 06:11 PM   #6
firehawk
Live Action!
firehawk's Avatar
You can plow my snow with it anytime you want
Old December 2nd, 2013, 06:53 PM   #7
mrclean
Silver Lake
mrclean's Avatar
O.k. I'm in. Just let me know if you need anything from your "east sider" friend. I still have the trailer and the truck if need be. Plus, it's always nice to venture over that way to see Amy and the girls (and yes, you too )
mrclean is offline   Reply With Quote
Old December 2nd, 2013, 07:05 PM   #8
jbsjunk
Little Member
jbsjunk's Avatar
Pitch the blocks and every other leaf. It'll still ride like a truck but it won't feel like the diff is welded to the frame. Air bags might help if you're going to haul heavy stuff.
Old December 2nd, 2013, 07:29 PM   #9
babyjp95
average guy
babyjp95's Avatar
Looks like its gonna be a sweet build, definitely subscribed.
babyjp95 is offline   Reply With Quote
Old December 5th, 2013, 07:39 PM   #10
TJrig
TJrig's Avatar
Looks cool Craig!
TJrig is offline   Reply With Quote
Old December 5th, 2013, 07:44 PM   #11
jbsjunk
Little Member
jbsjunk's Avatar
Needs a beaver tail now.
Old December 6th, 2013, 05:48 AM   #12
kmanxj5011
kmanxj5011's Avatar
Awesome!!!!!
kmanxj5011 is offline   Reply With Quote
Old December 14th, 2013, 05:42 AM   #13
1x1_Speed_Craig
Simplify...
I just secured a complete 141"-wheelbase 2005 F350 Super Duty Cab & Chassis frame not horribly far from my house.
The rear springs/axle from my earlier-model "frame cut" will bolt in. I will, however, have to round up some stock 2005+ Super Duty front suspension pieces (coils, torsion bars, etc.), along with a front axle, at some point. If anyone is replacing their stock 2005+ F250/350 Super Duty suspension with an aftermarket lift, I'm interested in your stock suspension parts.
This is the result of my (novice) Photoshop work, giving me a "blank canvas" to hand-draw in the rest of the custom vehicle build using my somewhat dormant artistic skills. Based on my calculations/estimations (many of which came from studying the drawings on the Ford Fleet "Body Builders Layout Book"...a GREAT resource!), the 141"-wheelbase F350 Super Duty Cab & Chassis frame should give me approximately the same bed length as the 1957 FC180 concept vehicle, but with a slightly longer wheelbase.
Old December 14th, 2013, 05:48 AM   #14
jbsjunk
Little Member
jbsjunk's Avatar
Just did a 4 link on a 08 F350 this week. The customer got all of his old parts tho. Coils, radius arms and frame brackets. Are you planning to have it 4x4 still then?
Old December 14th, 2013, 05:57 AM   #15
1x1_Speed_Craig
Simplify...
Hey Jeff. If they're interested in selling their stock parts, would you be willing to shoot me their contact info (or I can send you mine to give to them)?
Yes, I'm planning on it being 4WD, but I'll have to save and/or scour for a front axle once I do more research. I'd like to find a front axle from a DRW vehicle so I can use the DRW wheels front & rear.
Craig
Old December 14th, 2013, 08:59 AM   #16
mrclean
Silver Lake
mrclean's Avatar
Just shooting from the hip here, but would it be "possibly" more cost-effective to either somehow graft a car trailer plat form as a bed (that way you have a beaver tail, etc.) or possibly buy a used roll back set up from an old tow truck? Just trying to think of some different ideas. You know I love the "one the cheap builds"
Old December 14th, 2013, 10:01 AM   #17
1x1_Speed_Craig
Simplify...
Good idea, Travis. I'll keep this in mind further down the project.
Old December 14th, 2013, 03:19 PM   #18
Jsawduste
Jsawduste's Avatar
In
Jsawduste is offline   Reply With Quote
Old December 22nd, 2013, 08:27 PM   #19
1x1_Speed_Craig
Simplify...
A few updates...
I found someone who could use the heavy-duty 12-leaf rear springs from my "frame cut", and will be pulling them off the axle later this week.
My '98.5-'99.5 F350 rear "frame cut" is now stripped down to a bare frame, and will likely be going to scrap in the spring. I had originally planned on grafting the stock front half of my stock FC170 frame to the rear half of the F350 Cab & Chassis frame. However, I found that the stock FC170 frame isn't actually solid enough to work with, and there would be a LOT of fabrication work to get everything aligned properly, as well.
I did, however, find a complete 2005 F350 Cab & Chassis 141"-wheelbase frame that I'll be picking up about 1 1/2 hours from my house this Friday. I'll have to build custom cab mounts up front, as well as figure out how to set up the steering box on the new frame, which is about 7" wider than the stock FC frame up front. The DRW rear axle will bolt into the new frame just fine. 2005 is the first year that the F350s utilized coil springs up front, which leads me to my next find...
Timing is up-in-the-air depending on when the seller can get the parts pulled, but I'll be picking up all of the front & rear suspension-related parts, and the Dana 60 front axle a 2005 F350 (SRW) that was hit in the rear. I'm not sure yet about the gear ratio of the front axle, and will likely have to regear to 4.30 eventually to match the DRW rear axle I already have. I'll also have to locate some DRW front spacers to mount on this SRW axle. The biggest challenge, though, will be finding a set of wheels. 2005 introduced bigger brake calipers & rotors on the F350s, requiring a minimum 17" wheel diameter. Most 8 x 170mm dually wheels I have seen are 16" wheels, and to further complicate things, the later-model (bigger diameter) DRW wheels used a different bolt pattern (8 x 200mm). I have a couple 16" DRW wheels, and rounded up some others, as well. However, I'll have to research if these are even an option up front, or if I'll have to go bigger down the road (aftermarket DRW wheels are stupid-expensive).
Pics of the "new" frame to come at the end of the week.
Old December 22nd, 2013, 08:30 PM   #20
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
I know it's yours, but drop the drw and problem solved
Page generated in 0.61208 seconds with 84 queries
