Misc. 89-93 Dodge Cummins parts: Axles/parts, interior, cap, glass, wiring plow etc - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 1st, 2013, 10:37 AM   #1
Bookshelf
Default Misc. 89-93 Dodge Cummins parts: Axles/parts, interior, cap, glass, wiring plow etc
Parts from 89-93 Cummins Diesel Dodge trucks unless otherwise noted, no shipping on items like axles, plow etc
Fisher speedcast 8' plow setup, Edge trip plow, electric underhood pump, frame/lights/brackets/control/cables this is not a minute mount plow, the frame stays on the truck $550, call for details
Plastic fuel tank, no sending unit or fuel pickup, $free
1 each Michelin LTX M/S and LTX A/S LT265/75-16 load range E tires mounted on 2001 16x7.5 Dodge steel wheels 13/32" tread depth, $140 each
Dana 61 front 3.07, no hubs $250
Dana 61 front 3.54 no hubs $250
Dana 70u Single rear wheel rear axle, 3.54 gears, not posi, will need brakes $200
The following parts are from 91-93 SRW 32 spline Dana 70u rear axles:
Axle tubes with spring perches, spindles, backing plate mounting flange still intact, good for a fab project? $25/pair
Hubs, $50 ea, no good drums
Backing plates $20/pair
open carrier that had a 3.54 $35
Yoke $25
Axle shafts $20 ea
Lock right locker already installed in open carrier that had a 3.54 $320
Dana 60 front carrier had a 3.54 $30
Clutch/brake pedals no master cylinder bracket and post on clutch pedal where master cylinder rod goes is worn $30
Getrag clutch hydraulics complete $85
Steering box $50
Fixed rear cab glass, might have been from a Club Cab, not sure if it makes a difference, with gasket, $15
Aftermarket sliding rear window from a 1992 standard cab with gasket, $50
Door glass, vent windows, $call for price
Drivers side power window motor from a 93, $20
Heat/A/c control from a 93 $10
Gray glove box door from a 93 $5
Guage cluster from a 93, $100
Wood dash faceplate, no information centers $10
Tilt steering column from a manual trans. truck $50, no wheel, turn signal or ignition switches
"Cummins Turbo Diesel" plate that goes over the valve covers $30
Any wiring harness from a 93 5 speed Club Cab, also have a 92 harness that extends the length of the truck on the chassis $call
Gray console from a 93 with bucket seats, console only $20
Rear driveshaft from a 93 Club cab manual trans, 2 piece with carrier bearing, some play in the slip joint $50
Front driveshaft from a 91 manual trans, needs to be rebuilt $30
Passenger bucket seat, gray, decent shape, no armrest $25
Stock air boxes 89-92, and 93 styles, box and lid, $20
8' truck bed cap topper camper top, century brand, missing 2 of the 3 front and the rear windows $25
Please CALL, no texts please 630-254-2nine6five
Bookshelf is offline   Reply With Quote
Page generated in 0.25207 seconds with 26 queries
