Putting a tv over the fireplace? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 28th, 2013, 09:42 AM   #1
03tjsport
Red Dragons!
03tjsport's Avatar
Default Putting a tv over the fireplace?
Good or bad? I have a wood burning fireplace insert. Not sure how much we will actually have a fire.
03tjsport is offline   Reply With Quote
Old November 28th, 2013, 10:10 AM   #2
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
It depends how well your chimney vents. Mine lets some smoke out of the front of the fireplace a little with pressure changes.
Old November 28th, 2013, 10:15 AM   #3
wave_crusher
I'll Direc your TV
wave_crusher's Avatar
Mounted my grandpa's 40" over his fireplace, nothing underneath it; never had any issues. I thought that it would get to hot when he had a fire but it never gets hot at all; the tv stays close to the wall so the heat never actually gets to it from the front of the fireplace. Just like Rob said, as long as your chimney vents well (the wall doesn't get hot) you should be fine
Old November 28th, 2013, 10:21 AM   #4
Immortal
NO RELIGION WAT!
Immortal's Avatar
Schweeb just did this. Electricians installed wall outlet, fished speaker wires, and mounted his 60" TV above his wood burning fireplace.
Worst decision he ever made.
Melted wires and ruined his new tv.
Old November 28th, 2013, 10:23 AM   #5
SS
Bananarama!
SS's Avatar
Poor Schweeb.
-Jer
Old November 28th, 2013, 10:24 AM   #6
Immortal
NO RELIGION WAT!
Immortal's Avatar
Poor Schweeb.
Fuck him. He is a dick anyways.
Old November 28th, 2013, 10:27 AM   #7
SS
Bananarama!
SS's Avatar
Is that what you usually do? Fuck him? You sure do like dick.
-Jer
Old November 28th, 2013, 10:37 AM   #8
Immortal
NO RELIGION WAT!
Immortal's Avatar
You're gay. I get it. Sorry my feelings are not mutual. Doesn't mean we can't be friends.
Old November 28th, 2013, 10:38 AM   #9
SS
Bananarama!
SS's Avatar
-Jer
Old November 28th, 2013, 10:41 AM   #10
03tjsport
Red Dragons!
03tjsport's Avatar
Boo! We just moved here and have not used it yet. I need to get somebody here to check it out first. Looks to have a metal tube as the vent.
Old November 28th, 2013, 12:09 PM   #11
Rob the plumber
You'll probably be fine with the B vent. The wall shouldn't get hot at all unlike a masonry chimney. As long as the smoke doesn't get out, and the wall stays fairly cool, you're good.
Old November 28th, 2013, 12:46 PM   #12
jeepfreak81
81 inches of fun
jeepfreak81's Avatar
We moved ours to a corner, once I switch the tv out for a 50" the mount will hidden. We just moved in so I have not built the shelves for the cable box etc yet.
Old November 28th, 2013, 04:52 PM   #13
stereoguy
2jz NO SH*T!
stereoguy's Avatar
I have had mine on the mantel over the fireplace for 5 years now . A Samsung 46". LCD TV . It is still working great. Wood burning fireplace .
stereoguy is offline   Reply With Quote
Old November 28th, 2013, 05:01 PM   #14
Chiefwoohaw
Pokerob is my B*tch!
Chiefwoohaw's Avatar
Our old house had a 46" above it for 5 years with no problem and our current had had a 60" above it with no problem.
Reclined in the man chair is the perfect TV watching angle.
Old November 28th, 2013, 06:32 PM   #15
quicksilver
quicksilver's Avatar
My 51 inch over the fireplace has not been a problem in the 2 years its been there. Tho we don't use the fire place very often, mostly holidays.
quicksilver is offline   Reply With Quote
Old November 28th, 2013, 08:24 PM   #16
Ebs
Bad, it's way too high.
Old November 28th, 2013, 11:16 PM   #17
03tjsport
Red Dragons!
03tjsport's Avatar
This seems to be more of an issue than the heat.
Old November 28th, 2013, 11:29 PM   #18
Bones
Bones's Avatar
are we talknig a legit fireplace in which case you will be mounting the TV to a brick that can conduct heat from the chimney? Or are we talking a wood burning insert with an insulated chimney?
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old November 28th, 2013, 11:35 PM   #19
03tjsport
Red Dragons!
03tjsport's Avatar
Wood burning insert. No bricks. Chimney pipe looks to be boxed in with drywall.
Old November 29th, 2013, 08:07 AM   #20
amc78cj7
amc78cj7's Avatar
I'm sitting in my living room now and looked up above the fireplace from the chair sitting perpendicular...I think it would suck to have to look up at an angle at that location. In contrast out TV is on a stand at eye level and I can see it from everyplace in the room. I suppose if you only have a couch directly in front of the fireplace you will be OK.
I'm not quoting idiots who promote unsafe recovery strap techniques anymore. :miff:
amc78cj7 is offline   Reply With Quote
Page generated in 0.37817 seconds with 82 queries
