FC170 "Patina Rod" (of sorts)? Yay or Nay? - Great Lakes 4x4. The largest offroad forum in the Midwest
View Poll Results: Patina Rod?
Hell yeah. 26 83.87%
Nay? (Refer to Option 1) 5 16.13%
Voters: 31. You may not vote on this poll
Old November 27th, 2013, 05:42 PM   #1
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
Default FC170 "Patina Rod" (of sorts)? Yay or Nay?
The "canvas"? A 1961 (or so it appears based on the VIN) Jeep FC170. It's rough, but here's what I'm thinking...
  • Repair the floors in the cab and neutralize exterior rust as much as possible. Prep/paint the interior nicely, but retain the existing exterior paint scheme/patina, rust, etc.
  • Mount cab on late-model frame/axles...potentially dually rear axle, all painted satin black (clean).
  • Custom bumpers. The front may potentially have extra tubing work to pay homage to its former plowing glory.
  • Build flatbed on the back. Original bed is shot, so repair is not an option.
  • Install late-model, sub-100K mile Jeep 4.0L/AW4/NP-231 (I already own this driveline, and don't have the budget to consider other options, nor do I want to. It runs GREAT!).
  • Tire size? No idea yet.
  • Must be built with a very low budget.
Spew forth feedback and/or ideas.
Old November 27th, 2013, 05:46 PM   #2
crosseyed cat
safety cone killer !!!
crosseyed cat's Avatar
would be cool rig, could re fab box/bed !? get on it!!!
crosseyed cat is offline   Reply With Quote
Old November 27th, 2013, 05:59 PM   #3
wilesin
10ptbuck
wilesin's Avatar
If you can do it. Fucking do it!
wilesin is offline   Reply With Quote
Old November 27th, 2013, 06:02 PM   #4
I suck cocks. Lots of them.
locally famous
I dig it, and wouldn't take much to make a box that resembles that one.
Yay
Old November 27th, 2013, 06:05 PM   #5
jhnyquest
goof ball
jhnyquest's Avatar
I like it.
Old November 27th, 2013, 06:10 PM   #6
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
Do it Craig!
Old November 27th, 2013, 06:33 PM   #7
jeepers48
jeepers48's Avatar
Sounds great so far. Are you going with Cherokee axles/Tj, (cutting off the coil front brackets and weld leaf spring pads?) or going with something a bit beefier? Ford d44 w/9" rear? or 8 lug? Maybe look for a military trailer and use it for the bed?
jeepers48 is offline   Reply With Quote
Old November 27th, 2013, 06:36 PM   #8
BlooMule
Old School
BlooMule's Avatar
If you go flatbed, install non-removable stake sides so you don't end up in a gray area on commercial vs personal plates.
-rw-rw-rw
Old November 27th, 2013, 06:49 PM   #9
1x1_Speed_Craig
Simplify...
Kim, I'm currently looking at a Ford E350 cab & chassis dually rear. The rear will dictate the matching front.
Explain, if you would, BlooMule. I don't think I want stake sides, as I would get more utility (personal use) out of a flatbed. Why would questions about commercial use come into play?
Old November 27th, 2013, 07:15 PM   #10
fordbronco
the ocean called
fordbronco's Avatar
Sounds interesting.
Old November 27th, 2013, 08:02 PM   #11
BlooMule
Old School
BlooMule's Avatar
Never mind. I just looked it up here:
http://www.michigan.gov/sos/0,1607,7...9800--,00.html
Apparently a private owner can have a stake truck without having to have USDOT numbers.
My info was out of date. I had put a flat bed on a 72 Chevy 1/2 ton, and got a ticket for not having a GVW plate. All I had to do was screw stake sides on it (non-removable- one screw per stake qualified since a tool was required to remove) and I was good to go. Now that I think of it, this was 25 years ago. Damn, thank you for making me feel old!
-rw-rw-rw
Old November 27th, 2013, 08:15 PM   #12
skife
skife's Avatar
you know where i stand.
Old November 27th, 2013, 10:46 PM   #13
GREASYHANDS
GREASYHANDS's Avatar
Umm.... yes!
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old November 28th, 2013, 12:01 AM   #14
busyfixin
Balls Deep
busyfixin's Avatar
My vote is E-350 351W (turbo'd) or powerstroke donor chassis, 2wd, with slicks.
Old November 28th, 2013, 01:14 AM   #15
jbsjunk
Little Member
jbsjunk's Avatar
Regardless, this will not be a cheap build. You can find a JK rolling frame, add to the wheelbase and put air bags in the rear coils for any extra load. Put your engine/trans/t-case in and see what you will need to do with the doghouse to access everything.
You can look at the new concept Jeep FC to see how they got the steering to work.
Old November 28th, 2013, 07:54 AM   #16
93trackaddict
93trackaddict's Avatar
Rebuild the box
You could shorten the length of it between the cab and wheel well to make it the proper length for a different chassis
93trackaddict is offline   Reply With Quote
Old November 28th, 2013, 08:02 AM   #17
Chiefwoohaw
Pokerob is my B*tch!
Chiefwoohaw's Avatar
You'll just part it out so Nay in your case but Yay for anyone else. That could defiantly be awesome at some point in the future.
Old November 28th, 2013, 08:30 AM   #18
Spudy
Redneck Excavator
Spudy's Avatar
if you ever need a hand let me know man and im love the ideas. but im kind of partical to rebuilding the box.
Spudy is offline   Reply With Quote
Old November 28th, 2013, 08:54 AM   #19
1x1_Speed_Craig
Simplify...
Thanks, all. Keep the feedback coming.
...except you, woohaw. You already know I have zero respect for you, and your opinion. I could even look past your dickish ways if you had any fabrication/hands-on build credibility, but you really don't.
Old November 28th, 2013, 09:37 AM   #20
puckett
puckett's Avatar
I know a guy that found a factory wrecker boom for his fc build. I love the fc's.
puckett is offline   Reply With Quote
Tags
fc, fc150, fc170, forward control
Page generated in 0.40558 seconds with 83 queries
