Do I need to break my new gears in? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 24th, 2013, 07:11 PM   #1
TCxOUTLAW
TCxOUTLAW's Avatar
Default Do I need to break my new gears in?
Just put 4.56 gears on my cherokee d30/8.25..I've heard talk of having to break new gears in?
Sent from my LGL55C using Tapatalk 2
TCxOUTLAW is offline   Reply With Quote
Old November 24th, 2013, 07:32 PM   #2
Tab
Tab's Avatar
You should. But that's basically just driving it short distances to let them get warm/hot to wear off the coating and letting it cool down. And repeat. Also don't wheel them or tow anything for at least 500 miles.
Old November 24th, 2013, 07:58 PM   #3
Well I guess I'm screwed. I had exactly 7 miles on mine before I wheeled them.
I buy the wear in part but they don't get hot enough to do any form of transformation.
Old November 24th, 2013, 08:21 PM   #4
Tab
Tab's Avatar
I know you went to the mall today but that's not really wheeling.
Maybe that's why your last set broke apart?
Old November 24th, 2013, 08:22 PM   #5
Tab
Tab's Avatar
And I've never broke my gears in either. I put them in and every trip since has been wheeling.
Old November 24th, 2013, 08:42 PM   #6
mudrunner456
mudrunner456's Avatar
I just got my new front installed last week. Pulled out of the garage and went around the block in front wheel drive. Maybe a 1/4 mile. Then proceeded to do a sweet front wheel drive burnout in my driveway. Ooops
mudrunner456 is offline   Reply With Quote
Old November 24th, 2013, 09:01 PM   #7
TCxOUTLAW
TCxOUTLAW's Avatar
Alright,I have to drive it about 150 miles all highway to get my rig home,guess ill make a pit stop or 2 on the way home.
Old November 24th, 2013, 10:26 PM   #8
I suck cocks. Lots of them.
locally famous
Mine get broke-in from the garage to the trailer, seems to work ok
Old November 24th, 2013, 11:02 PM   #9
masterbeatty
masterbeatty's Avatar
ive never broke a set it, never seemed to have an issue
Old November 24th, 2013, 11:36 PM   #10
oz97tj
Wasn't this attached?
oz97tj's Avatar
I think the big thing here is to not overload / over heat them and you'll be fine.
On all mine, my jeeps were DDs so I just drove them like normal. Changed the oil after 1000ish miles.
********GLFWDA.org********
Old November 25th, 2013, 12:05 AM   #11
Wramblerguy
Wramblerguy's Avatar
I broke mine in
I think the paperwork said drive 30 miles then stop and let them completely cool then change lube after 1000 miles or something
All I have to say is the lube was prety dirty for the amount of miles I had on it
3rd generation jeeper
Old November 25th, 2013, 06:34 AM   #12
I think the real key is to stop often enough to make sure they are not over heating. I also think changing the fluid after a short time is a good thing.
Old November 25th, 2013, 06:37 AM   #13
lgottler
lgottler's Avatar
I broke mine in on the way to a wheeling run 8 hours away. Just stopped often and let them cool, takes a while for that much metal to cool though.
lgottler is offline   Reply With Quote
Old November 26th, 2013, 08:21 PM   #14
unclebeaner
can you hear the banjos?
unclebeaner's Avatar
garage to trailer lol
Page generated in 0.91126 seconds with 65 queries
