Post 97 Ranger 351 Swap? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 24th, 2013, 12:03 PM   #1
chasetheface123
chasetheface123's Avatar
Default Post 97 Ranger 351 Swap?
Is there anything to lookout for? I am picking up a 99 ranger, and doing the 351w/c6 swap out of a bronco. I have read that the exhaust is a trick, but is there anything other than that? The ranger is 2wd, if that makes any difference.
chasetheface123 is offline   Reply With Quote
Old November 25th, 2013, 09:08 PM   #2
Never_Evil
You will need a different transmission, the c6 out of the bronco will be 4x4. There are 351w ranger specific headers available to buy. Check out www.therangerstation.com I'm sure there are a few write ups.
Old November 25th, 2013, 09:28 PM   #3
sandguy356
bronco built for fun
sandguy356's Avatar
If space is an issue, and with most Rangers it is, you would be better off with a c4 setup. A c4 is a lot smaller and easier to work around in a tight spot.
sandguy356 is offline   Reply With Quote
Old November 26th, 2013, 07:53 AM   #4
chasetheface123
That's the reason I am using the c6?
Old November 26th, 2013, 07:54 AM   #5
chasetheface123
Sorry for the confusion. Going from 2wd to 4wd.. The 2wd frame rails are wider.
Page generated in 0.17906 seconds with 38 queries
