99 tj 4.0 auto no balls?? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 22nd, 2013, 08:09 PM   #1
snocross2xtremes
snocross2xtremes's Avatar
Default 99 tj 4.0 auto no balls??
99 tj 4.0 auto sport 3:73 gear
Good compression
33" tire
The jeep just has no power when ya step on it
No check engine light..
Old November 22nd, 2013, 08:12 PM   #2
jbsjunk
Little Member
jbsjunk's Avatar
Have all the gears? Low speed or highway no power?
Old November 22nd, 2013, 08:29 PM   #3
firehawk
Live Action!
firehawk's Avatar
All stock or has the motor or trans been swapped?
Plugged cat?
Old November 22nd, 2013, 10:06 PM   #4
I suck cocks. Lots of them.
locally famous
Try these
Benwa balls
I have five linked medium benwa balls only used twice...I bought them for the wife and she didn't care for them, so I tried them once. I can honestly say they weren't for me either. My loss your gain. $75 obo. I know people that like them really like them, I just couldn't get used to them. Maybe I need small ones?
Old November 23rd, 2013, 12:55 AM   #5
snocross2xtremes
As far as I know yes.
Plugged cat?
Not that I can tell but I do wanna change it
Old November 23rd, 2013, 08:31 AM   #6
Dylan
Dylan's Avatar
off the line or when you're trying to downshift? Mine had an issue of starting off in second off the line so it was gutless. Sticky gov. Try putting it in the gears manually and see if it makes a difference. If its not downshifting than TV cable? If it is downshifting but still slow, it may have to do with 33 and 3.73 lol.
Old November 23rd, 2013, 05:04 PM   #7
jeepers48
jeepers48's Avatar
X2 on the cat.
If it still has the catalytic convertor on it/ may be clogged? Had it happen on a ford once. had no balls till I cut the pipe to find out. Made a big difference.
jeepers48 is offline   Reply With Quote
Old November 23rd, 2013, 06:26 PM   #8
jbsjunk
Little Member
jbsjunk's Avatar
If there is a pre cat O2, you can pull it out and see if it works better and check for a plugged cat.
Old November 23rd, 2013, 07:10 PM   #9
revdog
I'd pull the o2 and see if it picks up power. Did yas check fuel pressure? Weres the initial timing set?
Sent from my DROID RAZR using Tapatalk 2
revdog is offline   Reply With Quote
Old November 23rd, 2013, 07:25 PM   #10
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
You can't adjust initial timing on a 4.0.
Old November 23rd, 2013, 08:27 PM   #11
revdog
But you can see where its at.
Old November 23rd, 2013, 10:03 PM   #12
Rob the plumber
There is a marker on the timing cover isn't there?
Old November 24th, 2013, 06:34 PM   #13
snocross2xtremes
gonna check the cat next.
Old November 24th, 2013, 07:35 PM   #14
firehawk
Live Action!
firehawk's Avatar
Meow?
Old November 24th, 2013, 07:57 PM   #15
bigbchevy
missmrgreenagain
bigbchevy's Avatar
Nuts
H.o.r.e
Old November 24th, 2013, 10:32 PM   #16
Wehan
Wehan's Avatar
I know it sounds obvious but did you check the air filter? Next easiest would be fuel pressure and then the fuel filter then the cat.
Wehan is offline   Reply With Quote
Old November 25th, 2013, 10:54 PM   #17
snocross2xtremes
air filter is new. have not check fuel psi yet.
Old November 27th, 2013, 01:22 PM   #18
idiot magnet
idiot magnet's Avatar
My cat busted apart and plugged up the muffler and did the same thing that you are describing.
idiot magnet is offline   Reply With Quote
Page generated in 0.33785 seconds with 77 queries
