YJ: ax15 internal to external slave swap problems - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 21st, 2013, 02:01 PM   #1
judgemikdredd
its a YJ
judgemikdredd's Avatar
Default ax15 internal to external slave swap problems
Iím in the process of swapping my internal slave ax15 to an external slave unit. I bought a new slave cylinder and it doesnít come with a bleeder screw. I tried to take what looks like one out of the old slave that came with the trans but what appeared to be a hex head is rounded out. Does anyone know if I can use a bleeder for something like a brake caliper? This has me kind of confused so any help would be awesome.
judgemikdredd is offline   Reply With Quote
Old November 22nd, 2013, 07:20 AM   #2
Dylan
Dylan's Avatar
to bleed a sealed clutch slave cyl, just point the piston down to the ground and pump the pedal a few times with the cap off the master. the fluid will push the air back up. You will have to pump 20 or so times. You may also have to unclip the plastic straps holding the piston in place, pump it out a few, and then press it all the way back in to force any more air out.
You can definitely bleed it without a bleed port. You can't use a brake bleeder because the hole isn't drilled for one. There are a few different versions out there. Some has bleeder screws, some has the plug like OEM and some have no hole for bleeding.
Old November 22nd, 2013, 08:27 AM   #3
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
I personally like the set up from Oreilleys. Master, line, and slave in a sealed, pre-bled unit. It's only like $140.
Old November 22nd, 2013, 02:30 PM   #4
Ebs
Put it all together (master, line, slave) and bleed it out of the vehicle. You can get the line somewhat straight and the whole assembly hanging vertical and pump the slave pushing the air up out the master.
Old November 22nd, 2013, 06:25 PM   #5
judgemikdredd
its a YJ
i gotm everything all figured out. thanks for the help everyone
Old November 23rd, 2013, 07:32 AM   #6
Dylan
Dylan's Avatar
post what you did so the next guy that runs into the same issue can follow. It helps when searching for this issue.
Old November 23rd, 2013, 06:22 PM   #7
judgemikdredd
its a YJ
i tried to get the bleeder out of the old slave an couldn't do it so i returned the slave i bought. then i got one from a different supplier and it had the bleeder already in it. bled it and it works fine now.
Page generated in 0.40322 seconds with 44 queries
