OTK 1 ton steering for scout 44's on my Cherokee - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 17th, 2013, 07:35 PM   #1
Seraphim Soldier
Always the hard way
Seraphim Soldier's Avatar
Default OTK 1 ton steering for scout 44's on my Cherokee
I have '90 Cherokee sport with scout 44's. The previous owner did the passenger to driver drop conversion and JANKED up the steering in order to make it work. The tie rod itself has a bracket welded on the passenger tie rod end to make it clear the bracket that was included for the track bar, and it needs tie rod ends replaced, but I also want to do a 1 ton OTK steering upgrade. The rod ends already go into the knuckle from the top, does that mean its already over the knuckle? I wanna buy a kit, should I get a kit for a jeep, or a kit for a Dana 44?
Seraphim Soldier is offline   Reply With Quote
Old November 17th, 2013, 09:52 PM   #2
Wramblerguy
Wramblerguy's Avatar
If your going to buy a kit it needs to be for the 44
Or you buy a DIY kit from like rough stuff and just do some cutting and welding
3rd generation jeeper
Old November 23rd, 2013, 02:41 PM   #3
VAhasnoWAVES
Dirty South
VAhasnoWAVES's Avatar
herp derp... yes, yes it does.
the important part is to figure out what taper your current rod ends use. if its not already GM 1 ton, youll also have to ream out the knuckles.
VAhasnoWAVES is offline   Reply With Quote
Page generated in 0.18883 seconds with 32 queries
