1996 F350 fuel tank skid - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 16th, 2013, 07:05 PM   #1
Dylan
Dylan's Avatar
Default 1996 F350 fuel tank skid
The fuel tank skid plate rusted out on our 1996 F350 with a poly rear tank. I've been looking for a new skid (or at least stapes) and have yet to find anything. The truck is gas. Anyone know of a new replacement? I may have to end up building a new one from scratch.
Old November 16th, 2013, 09:28 PM   #2
sandguy356
bronco built for fun
sandguy356's Avatar
Bronco graveyard?
sandguy356 is offline   Reply With Quote
Old November 16th, 2013, 09:40 PM   #3
Dylan
Dylan's Avatar
i thought of that but figured everything from a used one may have about as much rust. Would rather get a new one if they are still stamped. Problem I am having is it looks some I have some crazy setup and not sure where to even start. Its an f350 cube box truck. We had it built new in 1996. We ordered an single cab on a 4 door club cab frame in 4x4. This was so we can get the longest frame to put a van body on a 4wd chassis. It's a plastic tank (which I have read are only on the diesel trucks). Figured someone here may have some insight on exactly what setup we have.
It was all ordered new and we are the first owners so nothing was swapped out. I'm about ready to just pull the tank out completely and fab a whole new mounting system. From what it looks like the take is dropped in from the top with the bed off. There is no way I'm pulling a 16'x8'x6' van body off for a fuel tank.
Old November 25th, 2013, 01:30 PM   #4
fsumotorhead
N8KVB
fsumotorhead's Avatar
Sounds like a stock setup on a Bronco, top straps held up by the skidplate, that has "straps" stamped in.
Old November 25th, 2013, 02:04 PM   #5
Dylan
Dylan's Avatar
That looks a lot like it but the sides are open. Finally found a dealer that found the part. It's over $600 for the skid. I think I can fab one and then some for that.
Old November 25th, 2013, 05:22 PM   #6
fsumotorhead
N8KVB
FYI, that pic is the "old degign" the newer ones had open sides
Old November 25th, 2013, 06:16 PM   #7
Dylan
Dylan's Avatar
Do you know a part number or source?
Old November 25th, 2013, 09:38 PM   #8
fsumotorhead
N8KVB
This is what I remember, maybe a junkyard has one?
Old November 26th, 2013, 07:32 AM   #9
Dylan
Dylan's Avatar
that tank size and frame mount is a bit different. Out upper straps are almost flat across. Its a cab on chaise so I'm almost sure its different. I'm also almost sure that I won't be able to find one in a junk yard being that its also a 4x4 C&C.
Looks like building one it is. Thanks again for the help
Old November 26th, 2013, 08:35 AM   #10
fsumotorhead
N8KVB
No problem!
Ford is notorius, or was, for commonality. A Bronco tank on a C&C F-350 is not to hard to imagine, plus it fits right in the same location as a rear tank on regular F series pick up.
Page generated in 0.19001 seconds with 53 queries
