Yj blower motor problems - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 12th, 2013, 10:57 PM   #1
Wramblerguy
Wramblerguy's Avatar
Default Yj blower motor problems
Ok so the blower motor stopped working in my jeep
I figured out that the motor was getting power with a test light
I replaced the blower motor with the 72 blazer or w/e upgraded motor
Grounded it to the body of the motor
Get it back together and still nothing
The plug before the motor still has power
The plug has over 12 volts in all speeds of the switch though
I would think the voltage should be lower for slower speeds
My next step is going to be running jumpers from the battery directly to the motor to see if it works and if it does idk what to do next
I was hoping someone else has had the same issue or could help with some suggestions
Thanks
3rd generation jeeper
Old November 12th, 2013, 11:26 PM   #2
Toyfish
Toyfish's Avatar
I think the blower resistor grounds the motor to turn it on and off
Sent from my DROID X2 using Tapatalk 2
Old November 12th, 2013, 11:27 PM   #3
Wramblerguy
It's a 2 wire plug and using the multi meter on the two prongs I still got 12+ volts
Could it still be the resistor
It just can't support a load?
I'm not the best with electronics
Old November 12th, 2013, 11:30 PM   #4
Toyfish
Toyfish's Avatar
Yea it sounds like the resistor is bad i dont think they r very expensive so i would try that first
Old November 12th, 2013, 11:30 PM   #5
TJ/WILLYS
TJ/WILLYS's Avatar
Ground the case of the motor to the battery with a jumper wire
TJ/WILLYS is offline   Reply With Quote
Old November 13th, 2013, 12:10 AM   #6
Wramblerguy
I could do that but how did it ground before?
Old November 13th, 2013, 12:13 AM   #7
Wramblerguy
Ya the resistor is like $6 and easy to change
I'll look into that
Old November 19th, 2013, 10:14 PM   #8
Wramblerguy
New resistor didn't do it
Ground on the motor works
I can jump the wires and get the motor to work
I figured it was the speed switch so I removed that but I can't jump the terminals to get it to work
So it's not either of the switches
Idk what I'm missing here
Old November 22nd, 2013, 11:21 PM   #9
Wramblerguy
The power was weak so I just ran a new wire to it
It's just hot all the time so I have to turn the heat off when I turn the jeep off
Old November 22nd, 2013, 11:35 PM   #10
firehawk
Live Action!
firehawk's Avatar
Wire it to key on power
And use a relay.
Old November 22nd, 2013, 11:39 PM   #11
TJ/WILLYS
TJ/WILLYS's Avatar
Did you check the relay?
Old November 22nd, 2013, 11:42 PM   #12
Wramblerguy
I got tired of messing with it and tied of looking at wiring diagrams
I don't even know which relay it is
Old November 22nd, 2013, 11:48 PM   #13
TJ/WILLYS
TJ/WILLYS's Avatar
I'm going to guess you have a bad relay. It should be under pass. side of dash.
Old November 23rd, 2013, 12:07 AM   #14
Wramblerguy
Is that the only relay that is floating around under the dash?
I always wondered what that was for
Thanks
I'll check that out
Old November 29th, 2013, 06:35 PM   #15
WACKO1
2000 xj
WACKO1's Avatar
Ground is controlled by the heater control head
WACKO1 is online now   Reply With Quote
Old November 29th, 2013, 11:49 PM   #16
Wramblerguy
Ground of what?
The ground on the plug that plugs into the motor worked
Old November 30th, 2013, 06:36 PM   #17
WACKO1
2000 xj
WACKO1's Avatar
The blower is fed power from the fuse box to blower motor and the controller is the ground side
Old December 1st, 2013, 11:36 AM   #18
Wramblerguy
Mine isn't
The power goes through both switches before it gets to the motor
Page generated in 0.32307 seconds with 77 queries
