7.3 Diesel smokes at idle - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 12th, 2013, 06:43 PM   #1
chevyk10
FORD / GM
chevyk10's Avatar
Default 7.3 Diesel smokes at idle
Looking at buying an 03 F-250 Crew cab lariat 4x4 7.3 PSD fairly clean with 337k miles for a pretty decent deal. At cold start it smoked white smoke for a while, then was still puffing a good amount of white / blueish smoke once warm. I drove it for a good half hour, parked it and let it sit for about 5 mins, then it started puffing a good amount of white / blue tinted smoke again and progressively got worse. Got it back on the road and it'll clear right up with no smoke at all under load. At idle it roughs a little rough like its got a miss, but while driving it runs fine. Any ideas what this could be??? $5,200 for this truck seems like a good deal to me even with the miles and work it needs. The body is very solid and its a very nice looking truck. Has brand new tires 6 months ago and all new front end parts. Seems like a decent deal... but maybe someone here could help me out on this.
chevyk10 is offline   Reply With Quote
Old November 12th, 2013, 06:56 PM   #2
Bones
Bones's Avatar
if you are lucky it is only injector O rings. But it might be the injectors themselves...
unless it smelled like burning oil...
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old November 12th, 2013, 07:00 PM   #3
chevyk10
FORD / GM
chevyk10's Avatar
What would it be if it was burning oil? piston rings? Someone said could be the turbo? Also heard compression issues could cause this...
It was more white smoke than anything and got really bad after sitting at idle for a while. I just don't understand why it still runs fine and clears right up while driving... I had a duramax do exactly what this truck is doing, then one day BAM is blew a cylinder and left the entire city smoked out while driving it to the scrap yard.
Old November 12th, 2013, 07:06 PM   #4
Bones
Bones's Avatar
is it making proper boost and power? White smoke can be a host of things including unburnt diesel (if an injector was leaking).
Would the guy care if you took it somewhere and got a buzz test and cylinder contribution test?
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old November 12th, 2013, 07:11 PM   #5
chevyk10
FORD / GM
chevyk10's Avatar
Appears to make plenty of power. And the guy is a "mechanic" at an oil change shop and says he doesn't know much about these diesels and just selling them for a friend (already sold 3 others). I don't know if it is the injectors or not but I told him it needed all 8 new injectors to talk him down on the price. He didn't seem to know much about diesels, but I told him they cost $285 a piece and the IP would have to be replaced too ($700). Of course really I have no idea whats going on with it as I'm kinda new to diesels too. I have some experience with the 7.3 though and they are very tough long lasting engines if maintained.
Old November 13th, 2013, 07:29 AM   #6
frdboy
frdboy's Avatar
Like Bones said......white smoke is unburnt fuel, could be injector issues or low compression. I would pay a shop that knows diesels to do a compression test and look at the turbo.
Old November 14th, 2013, 12:11 PM   #7
NewXj
Mine had light blue to white smoke at all times..hot cold idle or on load. Turned timing advance( passenger side) .06 .....no more smoke
NewXj is offline   Reply With Quote
Old November 14th, 2013, 05:11 PM   #8
NewXj
If u need the funky wrench to loosen pump u can borrow mine or make one .
Old November 14th, 2013, 08:36 PM   #9
MilwaukeeF350
Dan
7.3L PSD DOESN'T HAVE injector pump. It use oil to fire injectors.
With the amount of miles I hope you check blow-by by remove oil cap.
Had one that lost #8 cylinder it was smoke like you describe. Were it idle smooth or had vibration that shake little?
Old November 15th, 2013, 03:35 PM   #10
snocross2xtremes
snocross2xtremes's Avatar
To many miles for me. Heck I could only get 8500 out my 01 with 180k on it
Page generated in 0.46885 seconds with 53 queries
