Coil Spring Towers From Barnes 4wd - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > Great Lakes 4x4 Marketplace > Vendors
Vendors Companies That Deliver Great Products Or Services and a list of companies offering GL4x4 Discounts
Thread Tools
Old November 11th, 2013, 10:47 AM   #1
Barnes 4wd
Barnes 4wd's Avatar
Default Coil Spring Towers From Barnes 4wd
So you want to build a custom link suspension, or stretch out your current suspension but you aren't ready to build it with air shocks or coilovers? Our coil spring towers are the best solution you will find for mounting coil springs to the front of your project. These Coil towers are made for 5.5 diameter coils which are the most common coil spring size used for the front of a rig. These coil towers are formed from one piece of steel to maximize strength and durability. The top of the tower will measure 7 from the top of your frame and we offset the tower so that you coils will not come in contact with your frame during suspension cycling. These come with two coil towers and two coil retaining plates.
They are $90 for the pair, and can be found here. Don't forget about our easy shipping policy!
Barnes 4wd is offline   Reply With Quote
Old May 31st, 2014, 12:07 PM   #2
Barnes 4wd
Barnes 4wd's Avatar
These towers are a great option for adding coils to one of our three or four link kits:
Old May 29th, 2015, 11:33 AM   #3
Barnes 4wd
Barnes 4wd's Avatar
Our coil spring towers are built in the USA from a single piece of steel and sold in pairs. We offset them to keep the coils from contacting your frame as your suspension cycles. Check them out online:
Thread Tools
Page generated in 0.41367 seconds with 32 queries
