disk brake conv on waggy 44 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 10th, 2013, 08:28 PM   #1
mudrunner456
mudrunner456's Avatar
Default disk brake conv on waggy 44
Looking for some input on putting disk brakes on a waggy. Ive een a few write ups but no one is saying if they are still able to run 15" rims. Which is what tires i already have. Any advice would be great.
mudrunner456 is offline   Reply With Quote
Old November 10th, 2013, 08:47 PM   #2
koochman450r
koochman450r's Avatar
Front 44?
you won this battle.
koochman450r is online now   Reply With Quote
Old November 10th, 2013, 08:51 PM   #3
mudrunner456
Rear
Old November 10th, 2013, 09:42 PM   #4
Wramblerguy
Wramblerguy's Avatar
I actually ground down the 1/2 ton Chevy calipers and pads to sit down on the rotor more
I used 89+ Chevy rotors and they fit on the axle flange perfect and weld on brackets
3rd generation jeeper
Old November 10th, 2013, 09:44 PM   #5
Wramblerguy
With this setup I have maybe a quarter inch clearance with the 15" wheels
It's still prety tight
I run aluminum wheels too, steel might be a little better
Old November 10th, 2013, 09:53 PM   #6
mudrunner456
Ok thanks. What rotors do you use.
Old November 10th, 2013, 10:03 PM   #7
Wramblerguy
89 to whatever rotors
1/2 ton Chevy front
Old November 10th, 2013, 10:09 PM   #8
mudrunner456
Ok thanks alot
Old November 10th, 2013, 10:19 PM   #9
Wramblerguy
No problem
Old November 10th, 2013, 10:47 PM   #10
Wramblerguy
One more thing
I had to do some custom grinding on the weld on bracket too
Just to fit the contour and be in the right location for the modified brakes
I think I used summit brackets, they were like $18 a piece
Old November 11th, 2013, 10:34 PM   #11
mudrunner456
Thanks
Old November 28th, 2013, 07:32 PM   #12
dmkx3
grave digger
dmkx3's Avatar
i'm running the same set up on my 06 wrangler. I was wondering if you knew what is the easiest way to set up a parking brake???
dmkx3 is offline   Reply With Quote
Old November 28th, 2013, 10:13 PM   #13
Wramblerguy
I think there is a special caliper you can use
Like a Cadillac or something that has a lever for a parking brake
Old November 29th, 2013, 06:55 AM   #14
dmkx3
grave digger
dmkx3's Avatar
thanks for the info
Old November 29th, 2013, 09:17 AM   #15
Dylan
Dylan's Avatar
early 80's Elderado calipers have the parking brake on them. They do cost a LOT more. i'm doing a disk conversion on a f350 now and will be using these calipers. Question for dmkx3, if you have a 06 wrangler, why didn't you just do a jeep/ford rear disk conversion? you could get that at most junk yards for about what paid for the chevy stuff and get the parking brake in the hat of the rotor.
Old November 29th, 2013, 12:13 PM   #16
dmkx3
grave digger
dmkx3's Avatar
My jeep now has the Chevy bolt pattern, I.E. The stock wagoner bolt pattern.
Old November 29th, 2013, 01:12 PM   #17
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
This is easy isuzu rodeo 44 rear disc with internal e brake
Old November 29th, 2013, 01:32 PM   #18
dmkx3
grave digger
dmkx3's Avatar
what if I didn't want to use the internal e-brake???
Old November 29th, 2013, 11:43 PM   #19
Wramblerguy
Aren't they bolted on brakes though?
I remember looking at them and seeing they were a little goofy
Plus the minor setback of metric fittings
Page generated in 0.30797 seconds with 81 queries
