99 Silverado Leaking Coolant - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 6th, 2013, 02:52 PM   #1
john_farina
Default 99 Silverado Leaking Coolant
I have a 99 silverado with a 5.3 v8. Awhile ago i started smelling burnt coolant. And a couple days ago i started seeing coolant on my driveway. I looked at my engine and it's not leaking from the water pump, or heater hoses. it looks like it's coming from the head gasket i think. im not 100% sure though. I was wondering if this was a common chevy problem? or if anyone has had this happen to them?
john_farina is offline   Reply With Quote
Old November 6th, 2013, 02:59 PM   #2
wave_crusher
I'll Direc your TV
wave_crusher's Avatar
intake gasket more like it; check your oil, if it is the head gasket the oil should be slightly milky unless it's only just started
Old November 6th, 2013, 03:03 PM   #3
john_farina
well it's been going on for about a month, but i checked my oil about a week ago and it seems fine.
Old November 6th, 2013, 03:16 PM   #4
joescamaro67
joescamaro67's Avatar
5.3`s dont have coolant in the intakes
I if it looks like the front of the head its more than likely the waterpump
joescamaro67 is offline   Reply With Quote
Old November 6th, 2013, 03:37 PM   #5
firestorm
x2. The intakes are dry on those.
It still wouldn't hurt to check the oil, in case there is a problem with the heads.
If it's concentrated on the passenger side, and especially if it is a considerable amount, I would check the coolant reservoir cap. I haven't had a problem with my Silverado, but I've seen those fail and spew coolant once the engine warms and pressure builds.
firestorm is offline   Reply With Quote
Old November 6th, 2013, 05:35 PM   #6
john_farina
well i changed the water pump a little bit ago, and it seems dry. its mostly damp on the drivers side.
Old November 6th, 2013, 06:08 PM   #7
firehawk
Live Action!
firehawk's Avatar
Check here p://www.chevytalk.org/fusionbb/showtopic.php?tid/211485/
Page generated in 0.19753 seconds with 44 queries
