SOLD!! 1979 Jeep J10 $2000 cash or Trade for Tractor only! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 5th, 2013, 08:13 PM   #1
Camo-5
And yet another Heap.....
Camo-5's Avatar
Default SOLD!! 1979 Jeep J10 $2000 cash or Trade for Tractor only!
Back up for sale. Looking to gather funds for a tractor.
1979 J10 Long Bed
The odometer says 90094 miles. I have no reason to doubt it, but donít know if itís factual either.
360 2V
TH400 (with 300 miles on full rebuild)
Quadratrac
stock axles
2Ē body lift, 2Ē add a leafs, new shocks
New starter / solenoid
New coil, wires and full tune up
All new brake hardware (including calipers and wheel cylinders)
New master cylinder
Several new axle U-joints
Partial new exhaust system
Lots of new lines and hoses
Just replaced the water pump
33Ē x 12.5Ē Cooper SSTs with 50%+ tread on Weld Aluminum truck rims (uber light)
Mechanically it runs / drives / stops good. Itís made several trips back and forth to Kalkaska from down here (230 miles) and Iíve never had an issue.
The body has the usual rust: bed sides, rockers and floors (I temporarily repaired these, but planned to do a downtown job this coming winter), but Iíve seem much worse.
As you can see Iíve converted the front end to a M715 look.
The interior is in decent shape also. Iíve painted (using appropriate vinyl paint and promoter) the interior to match the olive drab look on the outside. The original truck color was baby blue and that was not tolerable!!
The frame is in good shape. I did weld a couple plates onto the side of the front mounts for the rear springs to reinforce them since the metal was starting to look a little thin (typical for these).
Asking $2000
THIS IS NOT A PART OUT (INCLUDING WHEELS AND TIRES)!
No trades at this time unless you have a tractor (8N, 600, 3000, WD, etc.). No garden tractors please.
Thanks for looking!
ID:	111977   Click image for larger version
ID:	111978   Click image for larger version
ID:	111979   Click image for larger version
ID:	112490   Click image for larger version
Camo-5 is offline
Old November 5th, 2013, 08:43 PM   #2
ljense8
Web Wheeler
ljense8's Avatar
Sweet rig. Glws
ljense8 is offline
Old November 8th, 2013, 01:50 PM   #3
Camo-5
Camo-5's Avatar
Thanks! Weekend bump-a-roo.
Camo-5 is offline
Old November 18th, 2013, 05:51 PM   #4
Camo-5
Camo-5's Avatar
Bump.
Camo-5 is offline
Old November 26th, 2013, 09:46 AM   #5
Camo-5
Camo-5's Avatar
Sled worth $1000 or less added to list of trade items.
Camo-5 is offline
Old November 26th, 2013, 02:36 PM   #6
tleaf78
II got a beauutiful sled id trade staight up for it if yyou change your mind...wwhat axls are under it
tleaf78 is offline
Old November 27th, 2013, 07:08 AM   #7
Camo-5
Camo-5's Avatar
Thanks. Just looking for a beater sled for hauling firewood out of the woods when we get 3 feet of snow......
Dana 44s - stock
Camo-5 is offline
Old November 28th, 2013, 11:51 AM   #8
Camo-5
Camo-5's Avatar
Updated with additional pics.
Camo-5 is offline
Old December 5th, 2013, 08:19 AM   #9
Camo-5
Camo-5's Avatar
Price dropped a weee bit to $2300. Sled removed from trade options (picked one up last weekend).
Camo-5 is offline
Old December 7th, 2013, 08:29 AM   #10
Camo-5
Camo-5's Avatar
Final price drop. Got my eye on a tractor......
Camo-5 is offline
Old December 9th, 2013, 10:05 AM   #11
Camo-5
Camo-5's Avatar
Cash or tractor trade only.
Camo-5 is offline
Old December 16th, 2013, 07:55 AM   #12
Camo-5
Camo-5's Avatar
Bump. Loads of interest for 'after the holidays'. Get it while you can....
Camo-5 is offline
Old December 17th, 2013, 09:03 PM   #13
thormxboy420
FOUNDRY RATT
thormxboy420's Avatar
Send a message via AIM to thormxboy420
Pm sent
thormxboy420 is offline
Old December 17th, 2013, 10:25 PM   #14
Paul04TJ
Small, but talented
Paul04TJ's Avatar
Are you still at Chrysler? Haven't seen you in awhile.
Paul04TJ is offline
Old December 18th, 2013, 06:58 AM   #15
Camo-5
Camo-5's Avatar
I sure am. I work back in PDO now, so I don't get out in 'General Population' much....
All PMs returned.......
Camo-5 is offline
Old December 21st, 2013, 06:11 AM   #16
Camo-5
Camo-5's Avatar
Sold. Thanks GL4x4!
Camo-5 is offline
Old December 22nd, 2013, 07:49 PM   #17
Paul04TJ
Small, but talented
Paul04TJ's Avatar
PDO, that explains it. I've probably seen you but didnt recognize you with the pointy shoes and silk ascot around your neck!
Paul04TJ is offline
Page generated in 0.30304 seconds with 75 queries
