2007 Chev Impala 3500 V6 no heat - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 3rd, 2013, 07:37 PM   #1
tsaguy
Semper Fidelis
tsaguy's Avatar
Default 2007 Chev Impala 3500 V6 no heat
Looking for help from those who know...
1. Car stopped blowing heat while in idle, only when driving did it blow heat through the cabin.
2. Replaced thermostat, filled with coolant.
3. Still no heat.
4. Removed upper heater hose, filled coolant from here to try and bleed, but to no avail.
My questions are:
1. Is there a fail-safe way to bleed? Like a bolt or something? Or am I left to non-manufactured ways to bleed?
2. Does the heater core in these tend to build gunk inside?
Thanks for helping.
tsaguy is offline   Reply With Quote
Old November 3rd, 2013, 08:00 PM   #2
Toyfish
Toyfish's Avatar
Take a heater hoses off and blow compressed air thru the hoses in both directions.
Sent from my DROID X2 using Tapatalk 2
Old November 4th, 2013, 06:55 AM   #3
RADRICK
RADRICK's Avatar
Two common problems with these cars. First is head gaskets leak air into cooling system, causing air pocket in heater core. You may be able to see external leak from the headgasket leaking down the side of the block. Next there is a problem with getting air out of the system once the cooling system has been opened. IIRC you have to jack up the drivers side of the car to make it higher than the passenger side, disconnect the heater hose & fill with coolant, run engine to temp & burp the system with it jacked up.
Old November 4th, 2013, 07:43 AM   #4
tsaguy
Semper Fidelis
tsaguy's Avatar
Burp? I've read a few times on the 'net that I need to do it this way, but is the word 'burp' indicative of more action? Will give this a try this morning.
Old November 4th, 2013, 04:37 PM   #5
RADRICK
RADRICK's Avatar
burp= getting air pocket/bubble out of cooling system.
Old November 4th, 2013, 04:43 PM   #6
kickstand
circling the drain
kickstand's Avatar
Burp - Rub or pat its back gently after feedings.
Old November 4th, 2013, 05:05 PM   #7
IFS SUCKS
I like trees
IFS SUCKS's Avatar
 1. With the engine cooled off, remove the coolant pressure cap.
 2. Remove upper heater core hose from the metal pipe on the engine.
 3. Add coolant to the metal pipe, until full.
 4. Raise the rubber portion of the heater core hose as high as it will go with it still attached at the heater core. Using a funnel, add coolant until the hose is full.
 5. Reconnect the heater core hose.
 6. Start engine, have assistant raise the RPMs to about 1500 to 1700 RPMs, top coolant off at engine, then before lowering engine RPMs, install the coolant pressure cap.
 7. Fill coolant reservoir as necessary, then check the heat at idle.
IFS SUCKS is offline   Reply With Quote
Old November 4th, 2013, 06:08 PM   #8
tsaguy
Semper Fidelis
tsaguy's Avatar
I jacked the car up to raise the drivers side higher than the passenger side. Removed radiator cap, filled to the brim, filled coolant reservoir, removed upper heater core line, filled the metal part, removed lower hose, attached a clear line about 4 feet long and fastened to the nose of the opened hood. Using another clear line, I attached that to the upper hose and blew. As the fluid moved up the clear line, it also expelled air. I did this till no air escaped. Fastened the lower hose, filled the upper hose to full, fastened it back the return lines, and let the engine get nice and hot. Finally watched more air escape from the radiator fill point. Let it run for 20 minutes, and then replaced radiator cap. Topped off reservoir, and drove like I stoled it to get everything working right.
RADRICK-- You have helped me many times, and I thank you very much.
Thanks for the input all, /thread.
Old November 5th, 2013, 04:54 PM   #9
RADRICK
RADRICK's Avatar
Glad you got it figured out!
Old November 5th, 2013, 08:02 PM   #10
frdboy
frdboy's Avatar
Keep an eye on the coolant level, those had issues with the crossover tube gaskets leaking. There is a TSB and updated gaskets.
Page generated in 0.25618 seconds with 53 queries
