WTF are well inspections for? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 3rd, 2013, 07:05 AM   #1
jeepfreak81
81 inches of fun
jeepfreak81's Avatar
Default WTF are well inspections for?
We just bought a house, the well checked out so closing proceeded. This county requires to well to check out good in order to transfer a deed.
I have been here a week only to find the well pump is not turning off at all, it only appeared to be because the 44psi of pressure it could build on the gauge was all it could do, I was told it was a 40 psi switch.
I go to change the pressure switch when I realize the pump wasn't turning off to find the gauge is broken, and 10psi off.
In reality the pump is running 100% of the time and only building 30psi.
Does anyone have any idea's? This is going to get expensive I think
Old November 3rd, 2013, 07:22 AM   #2
jimhri
jimhri's Avatar
well well well....the joys of homeownership.
if you need any work done to the pump, etc., see if they can set up a hand pump [pitcher pump] along side if it's not too deep. this way if power fails you will have access to good water and get a little exercise.
jimhri is offline   Reply With Quote
Old November 3rd, 2013, 07:26 AM   #3
Silver Bullet
Livin the American Dream
Silver Bullet's Avatar
They don't check for functionality. They are checking to make sure the tank is not cracked, it has been pumped and test the water quality to make sure the septic is not leaching into the well water.
Silver Bullet is offline   Reply With Quote
Old November 3rd, 2013, 07:27 AM   #4
aber61
aber61's Avatar
The well inspection is to test the water quality for impurities, has to have ours done when we bought.
aber61 is offline   Reply With Quote
Old November 3rd, 2013, 07:29 AM   #5
jeepfreak81
81 inches of fun
That explains it then
Old November 3rd, 2013, 07:55 AM   #6
2TrakR
Rider of Trails
2TrakR's Avatar
Ours is a in-well pump (below ground). Not sure if yours is the same.
When ours did this...
The pump is going bad or there's a leak somewhere between the pump and the house. Our well had the fitting off the well case corrode and leak. Ground was saturated from the pump constantly running and pumping water "around" the well and low pressure in the house lines. The well guys dug down to the line and replaced the fitting.
Later on the pump failed (few years). Low pressure, erratic behavior, no water.
Then the well guys pulled the old pump/pipe and put a new pump in.
2TrakR is offline   Reply With Quote
Old November 3rd, 2013, 07:59 AM   #7
jeepfreak81
81 inches of fun
My pump and pressure tank both are in the ground. I wouldn't have expected a failure yet, none of it is all that old
I have no saturation around the well though, and didn't all summer while we looked at the house.
Old November 3rd, 2013, 08:05 AM   #8
Tie Dyed
O.G.
Tie Dyed's Avatar
Send a message via AIM to Tie Dyed
Make sure you have 220 at the pump. Some pictures of your well head and pressure tank would help.
2000 XJ with a 3 inch body lift
Tie Dyed is offline   Reply With Quote
Old November 3rd, 2013, 08:16 AM   #9
jeepfreak81
81 inches of fun
Not much to see... pressure tank is in the ground by the well head.
Old November 3rd, 2013, 09:09 AM   #10
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
never mind...
Yetti
Old November 3rd, 2013, 09:54 AM   #11
Brods
Burying the pressure tank, YIKES. It looks like it is an accepted thing: http://www.aquascience.net/amtrol-pr...dex.cfm?id=908
Can't imagine why anyone would bury it considering all the effort it will take just to check that its not leaking. Both houses I've owned with a well had to have the pressure tank replaced. Both failed from corrosion starting on the inside of the tank.
Basic piping 101.
The switch piping should not come off the bottom of the main line. That lets sediment build up in the piping, switch and gauge (which might be what caused the first gauge to fail). Better to rotate the tee so it points up or, if there is not enough room above the pipe, move the tee to the vertical run.
Old November 3rd, 2013, 10:17 AM   #12
jeepfreak81
81 inches of fun
Basic piping 101.
My dad and I had already talked about moving the switch and gauge. It was full of sediment when I removed it. It's been that way since the house was built though.
The first tank in this house lasted 20 years. I just did the math and it has been about 16 since that replacement.
Old November 3rd, 2013, 10:39 AM   #13
I suck cocks. Lots of them.
locally famous
The fitting on my pump eroded through, and was losing pressure from inside the pipe.
Old November 3rd, 2013, 04:36 PM   #14
firehawk
Live Action!
firehawk's Avatar
Your inspector should have caught a problem when he inspected the property, no?
Old November 3rd, 2013, 04:57 PM   #15
jeepfreak81
81 inches of fun
I would have thought so, but it was showing the correct pressure for the switch. The problem comes in that the gauge on the well was not reading correctly. He did not hook up his own gauge.
The separate well inspector I thought checked functionality as well, apparently not.
Old November 3rd, 2013, 05:19 PM   #16
MonkeyBiz
Master Cocksman
MonkeyBiz's Avatar
When I had the well inspection they checked for functionality and water quality. Had to work with the seller to get a new well dropped before closing progressed. Set us back over a month, and a couple grand.
Old November 3rd, 2013, 05:24 PM   #17
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
They certainly make their money on those pumps. I replaced one recently for $1200. And I made pretty good coin on that.
Sent from my SM-N900T using Tapatalk
Old November 3rd, 2013, 05:26 PM   #18
MonkeyBiz
Master Cocksman
MonkeyBiz's Avatar
I should add that that couple grand included going from a 2'' jet siphon well, to a 44 foot, 4'' well with a replaceable pump/point, and a new pressure tank
Old November 3rd, 2013, 05:28 PM   #19
2TrakR
Rider of Trails
2TrakR's Avatar
Never heard of a buried pressure tank but I don't get out much... I would suspect it first, it and/or the lines. Of course, I have zero "well-skills" so not much help...
Old November 3rd, 2013, 05:39 PM   #20
Badphish
Open up the cap on the well there is usually splice there there that I have saw fail. Burried tanks suck we only used them on modulars or trailers where we couldn't atank underneath. If you have a friend who's an electrician the may be able to megger test the motor for you also.
Badphish is offline   Reply With Quote
Page generated in 0.60125 seconds with 82 queries
