Explorer ABS delete? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 31st, 2013, 07:27 PM   #1
holshotracer
Its not mine
holshotracer's Avatar
Default Explorer ABS delete?
My 95 explorer is sitting on full width 44 and 9 inch. I swapped out the rear drums for disc and now i'm having issuses getting the brakes to work right. There is some what of a pedal but i can press though it. Some times it locks up the rear and some time it doesn't.
I bleed the brakes again and still the same, it still has the factory abs on it, i had good brakes with the rear drums. I was just wondering if it was worth the hassle of trying to delete the abs all together.
holshotracer is offline   Reply With Quote
Old October 31st, 2013, 07:38 PM   #2
Toyfish
Toyfish's Avatar
Sounds like u need a different proportioning valve
Sent from my DROID X2 using Tapatalk 2
Old November 6th, 2013, 07:51 PM   #3
holshotracer
Its not mine
got them better, i adjusted up the push rod between the booster and mc. the only problem is i went a little too much so the rears are dragging and getting warm.
Old November 8th, 2013, 08:41 AM   #4
fsumotorhead
N8KVB
fsumotorhead's Avatar
I'm not sure if the Explore has the same ABS module, but when we swapped axles on my brothers Bronco, we let the brake hoses hang (probably for days) I figured it would be an easy bleed later. Boy was I wrong!
We could never get all the air out, no matter how many times we bled it, it would require two pumps to get a firm pedal.
We needed to search out one of the Ford/Teves special tools for bleeding the 4WABS unit, otherwise it will always hold air.
The only other option is to remove the ABS unit, and install a adjustable proportioning valve.
Info on the bleeding tool:
http://www.mn12tech.com/brake-fluid.php
Page generated in 0.27709 seconds with 35 queries
