Best Rear Axle - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 27th, 2005, 09:31 PM   #21
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
Originally Posted by 1993Bogger
There is no application. I didnt ask what you would put under ur heep, just which axle gives you the best bang for the buck. and if u dont know what that means, ill explain. if you were to go and buy these three axles stock, which one would be the cheapest and the strongest? From my expeirence the 14 bolt takes the cake. and as far as the 9" goes, unless u want to sink a grand or 2 into one, then you will have one relativly strong compared to a 14bolt
That doesn't make any sense... because I'm sure there is some dump truck axle you can buy for $10 used.
A 14 bolt is probably the strongest, cheapest, most available axle out there... but unless your running 39"+ tires is completely retarted... and then with 39's you have the same clearance as a pair of 44's on 36's.
JcrOffroad
Zoom Zoom!
Old December 27th, 2005, 09:55 PM   #22
Originally Posted by Tonka
bigger tire= more stregnth needed from the axles. Figure out the clearances you want, and go from there. my thoughts:
biggest tire I'll run is a 37. dana 44's can hold up to them if some care is taken. my dana 30 was fine on 36's,
I'll take the clearance and higher risk of breakage over a dana 60 with the same size tire(this excludes high clearance 60's on the market, as some have more clearance than a dana 44)
Then again, Bigger axles need bigger tires to clear them...
Charo does have nice breasts....
Old December 27th, 2005, 11:41 PM   #23
PavementPounder
PavementPounder's Avatar
I vote for the D70....since I have one. Smoother bottom than the 14 and wider range of gears than the D60. I found mine in an old Dodge RV.
Old December 28th, 2005, 01:50 PM   #24
Mclovin
"The Situation"
Mclovin's Avatar
you're all wrong !!!
This is the best
Page generated in 0.21719 seconds with 35 queries
