XJ Dana 30 locker,Good or bad? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 29th, 2013, 04:53 PM   #1
TCxOUTLAW
TCxOUTLAW's Avatar
Default XJ Dana 30 locker,Good or bad?
Looking to throw a locker in my dana 30 on my 01 xj.. Anyone have any problems? Looking at the aussie or spartan..Any feed back would be great!
TCxOUTLAW is offline   Reply With Quote
Old October 29th, 2013, 05:29 PM   #2
Toyfish
Toyfish's Avatar
Ive been running one in my tj for over a year now as a dd and its fine. i would maybe be worried in the snow it might slide around being locked in the front.
Sent from my DROID X2 using Tapatalk 2
Old October 29th, 2013, 05:31 PM   #3
TCxOUTLAW
TCxOUTLAW's Avatar
i do alot of driving in the snow too
Old October 29th, 2013, 05:33 PM   #4
Toyfish
Toyfish's Avatar
Yea i havent drove mine in the snow but i know it drives horrible on dry roads in four wheel drive but it drives fine in two wheel drive your best bet would prolly be a tru trac unit
Old October 29th, 2013, 06:35 PM   #5
wilinsonlevi
Team Thumbs Up
wilinsonlevi's Avatar
Bad idea to daily drive with locked front in 4x4 mode.
Old October 29th, 2013, 06:39 PM   #6
1 ton tj on 40's
1 ton tj on 40's's Avatar
x9999999999999999999999999999999999999999. bad idea you will not like the out come
Old October 29th, 2013, 07:06 PM   #7
TCxOUTLAW
TCxOUTLAW's Avatar
i gotta drive thru everything with my job.. if roads are shut down i still have to go thru it all, so just looking to beef things up a bit for the winter..should i rule out a locker for my rear?
Old October 29th, 2013, 07:11 PM   #8
TCxOUTLAW
TCxOUTLAW's Avatar
Already adding 4.10 gears as well
Sent from my LGL55C using Tapatalk 2
Old October 29th, 2013, 07:20 PM   #9
wilinsonlevi
Team Thumbs Up
Rear can be sketchy on slippery roads. I'd suggest selectable lockers.
Old October 29th, 2013, 08:01 PM   #10
TCxOUTLAW
TCxOUTLAW's Avatar
Recommend anything kinda on a budget already doing a motor swap plus the gears so moneys a little tight but there is some room.. first time buying lockers for my rig
Old October 29th, 2013, 08:04 PM   #11
af26yrs
af26yrs's Avatar
I would recommend Detroit True Tracs in both axles. They are good in the snow and is what I am running. I had them in my WJ in both axles and could not be stopped in the snow, really loved them.
af26yrs is offline   Reply With Quote
Old October 29th, 2013, 08:05 PM   #12
Toyfish
Toyfish's Avatar
Your best fit would prolly be a set of tru trac limited slip units at about $500 each.
Old October 29th, 2013, 08:53 PM   #13
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Fyi If you actually wheel it you will be greatly disappointed with any sort of limited slip.
And I know of lots of people who DD with lunch boxes in the front with no ill side affects, myself included. However when a lunch box is installed in a rear application it can be tricky to drive at first, but with in a week your passengers will never know the difference.
I like and am currently running Spartans myself. Much smoother than any Aussie or Lockright that I've experienced. As for longevity, I've noticed that Aussies and Lockrights both have around a 2 year life span in a DD/wheeler. No long term experience in a dd for a Spartan yet.
One more thing, Take a long hard look at installing deeper gears than 4.10's. Cost is the same for all the gear sets and you don't want to have to do it twice. Check out RMS in my sig for locker and gear needs, or Unlimited Offroad if you need anything installed
Old October 30th, 2013, 04:02 PM   #14
TCxOUTLAW
TCxOUTLAW's Avatar
"lunch box" lockers were what i was thinking about doing.
as far as gears i was told any bigger and i would loose a lot of mpg,being that i drive 100+ highway miles a day i don't wanna totally kill my mileage
Old October 30th, 2013, 04:13 PM   #15
wakeboard76
wakeboard76's Avatar
I can second the vote for spartan lockers, have installed both Spartans and lock right lockers, the spartan pins are bigger and stronger and in my opinion easier to install. As for driving with a lunchbox that is up to your preference, I've had one in the rear of my dd tj for 2 years and didn't mind a bit, you just have to understand that the rear end may step out on you a bit easier. In deep snow the lockers are awesome. I now have Spartans in the front and rear of my dd tj, but I do have lockouts as well.
wakeboard76 is offline   Reply With Quote
Old October 30th, 2013, 06:51 PM   #16
Wehan
Wehan's Avatar
Aussie Aussie Aussie! No tire size limit or horse power limit stipulated in warranty, this tells me they have confidence in there on product. Spartan Dana 30 locker states a 32" tire max..... Just like the old Detroit EZ Locker, and look how that turned out. Also order a hardened cross shaft and new thrust washers with the Aussie, it's just good insurance and will insure a seamless problem free install.
Wehan is offline   Reply With Quote
Old October 30th, 2013, 07:02 PM   #17
wilinsonlevi
Team Thumbs Up
I stripped the gears on my spartan. Only has 3 or 4 trips on it.
Old October 31st, 2013, 09:41 PM   #18
TCxOUTLAW
TCxOUTLAW's Avatar
Going with 4.56 gears.. not gonna lock the rear but will be locking the front D30, the aussie sounds good and i like the price and warranty..
Old November 5th, 2013, 06:07 PM   #19
Immortal
NO RELIGION WAT!
Immortal's Avatar
I had the Detroit easy locker. Loved it, but broke stuff in it so I shelved. Installed a true trac. Loved it till I realized my front axle won't climb a boulder with one tire
Old November 8th, 2013, 01:47 PM   #20
Wehan
Wehan's Avatar
I also have a shelved EZ locker, Mine just refused to work. I don't think it's wore out or anything just a turd from day one. I called Eaton and they basically told me I had an expensive paperweight.
Page generated in 0.35818 seconds with 83 queries
