who has replace rockers and cab corners on a 02 range GM truck? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 28th, 2013, 11:35 PM   #1
barry1me
Just another day
barry1me's Avatar
Default who has replace rockers and cab corners on a 02 range GM truck?
My father in law has a 02 Sierra 2500HD that has rusted out rockers and cab corners. I have been doing some reading online and it looks like new parts can be had for $300. I was curious if anyone has replaced these before to get an idea of how hard of a job it is.
barry1me is offline   Reply With Quote
Old October 29th, 2013, 12:01 AM   #2
scare-crow
the eskimo bro
scare-crow's Avatar
Send a message via AIM to scare-crow
Invest in a spot weld drill.
scare-crow is offline   Reply With Quote
Old October 29th, 2013, 05:34 AM   #3
skife
skife's Avatar
EBay for cheaper panels or lkq
Old October 29th, 2013, 05:40 AM   #4
stereoguy
2jz NO SH*T!
stereoguy's Avatar
My buddy works at a body shop and told me they charge about 5k to do them.. It's about one full week of work to do . They take the bed off the doors and front fenders to have access to the panels. Then cut out a million spot welds . I need to do this also . His advise is do one side at a time so the cab won't flex. He has done a few dozen . The parts are cheap ,the labor not so much!
stereoguy is offline   Reply With Quote
Old October 29th, 2013, 05:57 AM   #5
Trailrig
Hoggin'-N-Boggin'
Trailrig's Avatar
Send a message via AIM to Trailrig
I paid autopride in flushing and they did a awesome job on my 2000
Definitely worth the money
Trailrig is offline   Reply With Quote
Old October 29th, 2013, 06:45 AM   #6
skife
skife's Avatar
Keystone for cheap sheetmetal, they are a division of lkq
Old October 29th, 2013, 07:19 AM   #7
barry1me
Just another day
barry1me's Avatar
wow $5k!!
Old October 29th, 2013, 07:50 AM   #8
Tom
Because racecar
Tom's Avatar
That's not a very good friend. My buddy quoted me $2500 for BOTH sides of mine. You need to find new friends.
Old October 29th, 2013, 07:50 AM   #9
gmotox
gmotox's Avatar
A local body shop did the rockers on my Dodge for $1000.00 and quoted a friend to do his Chevy rockers $1600.00
Old October 29th, 2013, 07:52 AM   #10
Tom
Because racecar
Tom's Avatar
he needs cab corners too.
PM Firehawk and see what he would charge, he works at body shop and does work on the side.
Old October 29th, 2013, 08:41 AM   #11
swampjeep
Swamp Stomper
swampjeep's Avatar
and how much did they charge?
I should probably just PM Firehawk.
swampjeep is offline   Reply With Quote
Old October 29th, 2013, 12:36 PM   #12
barry1me
Just another day
barry1me's Avatar
I just spoke to a family friend that does a lot of body work and he does rockers/cab quite often on GM trucks....he said there is about $300-$400 in materials (paint/rockers/epoxy) and he typically charges about $1200. He said he has had to charge up to $2000 for a crew cab that had significent damage to the vertical internal rockers and both sides shot.
Old October 29th, 2013, 04:04 PM   #13
Trailrig
Hoggin'-N-Boggin'
Trailrig's Avatar
1600 but also did some repair on my box and removed my decals
Old October 29th, 2013, 04:11 PM   #14
mudbuster
I've done quite a few of them and the shop I work at charges $1500/side for rocker and cab corner if it needs more than those two parts it's more. Let's put it this way my 01 needs them and I still havn't done them. I fixed my totaled 03 instead of doing the rockers on my 01 even though the 01 would be worth more money than the 03 lol
mudbuster is offline   Reply With Quote
Old November 3rd, 2013, 08:39 PM   #15
barry1me
Just another day
barry1me's Avatar
looks my father in law has a guy doing the rockers for $700 total. Pretty good deal considering the parts are $300 for this job.
Old November 5th, 2013, 05:56 AM   #16
stereoguy
2jz NO SH*T!
stereoguy's Avatar
I thought you were talking about the whole rocker panel . The outer ,the middle and the inner one . If you don't replace them all it's just cosmetic. They all rust out that is why so $. If you do just the outer cosmetic one then it's only a few hindered dollars . They are easy to do . I'm doing the outers in a few weeks on mine . The parts are only 350 and should only take a day or two at most . The sad thing is if you were to do this right it's about a weeks worth of work at a body shop and it's quite expensive. The parts are 700 to 800 alone for the full panels and cab corners . I use Lmc truck parts ,they are thicker than most . Good luck ! I'll do a thread on mine when I do them .
Page generated in 0.31525 seconds with 71 queries
